coolant temp.
ravennexus
where is the temperature gauge supposed to sit in normal running.
my 87 325i takes a fair amount of time to warm up then sits on the mark between the middle and cold.
i think the thermostat may be on the way out
dazleeds
- old skool raver
should sit pretty much at half fella
mine was sitting very low a while back changed blue sensor and t stat prob solved
www.oldskoolfantasy.co.uk
ravennexus
thought it should be something like that. most manufactures (except frenchies) have it in the middle of the range.
thanks.
just popped on GSF and ordered the stat, and all 3 gaskets for the exhaust seen as it's blowing somewhere at the engine.
thanks.
Morat
I think the blue sends temp to ECU, brown to the gauge - but what do I know, my temp gauge is a lying git!
pnd
on the 1/4 line between middle and cold is ok. most sit at half way but I have a car that sits at a quarter that is fine new thermostat and nearky everything else to do with temperature.
ravennexus
true, but in summer it was sitting slightly above the 1/4 line. now it's slightly below and on my drive to work it won't even get up there.
on bosch stuff Blue is usually the ECU sensor and Brown Temp.
only want to sort it out really because with it not warming up properly the ECU will see cooler then normal coolant temps and enrich the mixture
cass1_5503
i have this problem but its on my m40 engine is it the same sensors or are they different
Chris-W
Anywhere between the two coloured zones is normal operating temperature. The whole centre section of the gauge only covers a few degrees, and anywhere there is fine.
Most E30s run between just above the quarter mark and the half way mark.
Gouki
in between the quarter and half way mark for me.
cliffybabe
- Powered by Nelly
my coolant temp went mental a little while back and it turned out to be a crack in the neck of the expansion tank.
Now it sits on about 1/2 or just under, must admit though sinc ethe 6 branch went on the engine temp has seemed a little bit higher.
ravennexus
tonight on the way home is didn't even get out of the blue mark,
deff sounds like sticky thermostat.
cass1_5503
it will take a good half an hour to 45 mins to get to thatBrianmoooore wrote:Anywhere between the two coloured zones is normal operating temperature. The whole centre section of the gauge only covers a few degrees, and anywhere there is fine.
In that case you need a new 'stat as well.cass1_5503 wrote:it will take a good half an hour to 45 mins to get to thatBrianmoooore wrote:Anywhere between the two coloured zones is normal operating temperature. The whole centre section of the gauge only covers a few degrees, and anywhere there is fine.
E30 heater should be giving usefull heat after about a mile.
cass1_5503
no i get to work by the time the heater warms up its crapBrianmoooore wrote:In that case you need a new 'stat as well.cass1_5503 wrote:it will take a good half an hour to 45 mins to get to thatBrianmoooore wrote:Anywhere between the two coloured zones is normal operating temperature. The whole centre section of the gauge only covers a few degrees, and anywhere there is fine.
PiperZero
I've changed my expansion tank (it's turned brown and sprouted leaks), and once the temp gauge worked, it'll sit on half most times. Idling in traffic will push it about a couple of millimeters to the right.
ravennexus
put the new stat in yesterday, warmed the engine up, bleed the system, ran some more and rebled to make sure.
went out today engine was out of the cold section in less then half mile then up just under half on the way past the house on the way to the cinema where is stayed regardless of heater use.
