325 conversion shopping list.....
bazman
Post Sat Oct 28, 2006 6:59 pm
Following bimmamans thread about engineers reports for his conversion, could you helpful lot help me compile a list of the things Ill need to buy to make my 318i into the above?
Starter for 10 is the front brakes fitted are already from a 325i, and its running on lowered springs,(-40mm IIRC), dunno what difference this makes so far, so what else do I need please?
Mods feel free to move if should be in tech help?
Thanks in anticipation.
Baz
"Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life." - Terry Pratchett.
Theo
Post Sat Oct 28, 2006 7:26 pm
Ideally you will want;
325i front legs (51mm)
325i shocks all round
325i springs all round
325i Roll bars, you may not even have one on the back
325i diff (3.91, 3.64 etc)
325i gearbox
325i engine, inlet, tb, afm, loom, rad
ABS? If you really want to take time
325i exhaust system
Rear disc conversion
No doubt other bits i've forgotten, coding plugs etc
alan325i
Post Sat Oct 28, 2006 9:50 pm
or for the cheaper and quick option..................... sell ur 318 and buy a 325i
bazman
Post Sun Oct 29, 2006 10:21 am
Wow, didnt realise so much would be needed, methinks alan's plan is not a bad one, or try and find a donor and rob as much as poss off that. I am quite attached to my car, and doing this conversion will help me to learn more about it, in terms of maintenance and repairing it.
Food for thought, so thanks guys. :cool:
harry_p
Post Sun Oct 29, 2006 11:00 am
i've had similar thoughts at various points with different cars, in the end it always seems to be quicker, easier and cheaper to just buy the model rather than trying to upgrade from a lower spec. something a lot of people don't like doing as we tend to get attached to our cars!
however, if your shell is very good, with no signs of rust in the usual place, it may well be worth looking out for a mechanically good, but roten body 325.
at least if you have a complete donor car youre not going to miss anything, just be prepared for it to take twice as long as you first thought!
fuzzy
He who sleeps with "Gingers"
Post Sun Oct 29, 2006 11:23 am
i dont understand why people bother with 2.5 conversions instead of just buying a new car.if your going to go to the trouble of an engine conversion you might as well go for something bigger like a 3.5 or even something more unusual :?
Post Sun Oct 29, 2006 12:24 pm
fuzzy wrote:i dont understand why people bother with 2.5 conversions instead of just buying a new car.if your going to go to the trouble of an engine conversion you might as well go for something bigger like a 3.5 or even something more unusual :?
Disagree. I find that 316, 318s tend to be much more unmolested and in better body condition than 325s.
There is also the insurance peculiarity, that a 316 with an engine change can be cheaper to insure than a 325.
Rusty/accident damaged donor is the way to go though.
Agree with fuzzy to a degree though, but it's a lot easier/quicker to do a M20B25 conversion for a transplant virgin than to attempt something more advanced as a first go.
eamo
Post Sun Oct 29, 2006 2:53 pm
you'll also need an oil cooler and the engine loom
Alyman
Post Sun Oct 29, 2006 3:40 pm
its something thats been crossing my mind a lot over the last few days as I battle to get the M40 going again. I've got a 325i convertible sitting out the back of the flat just now, which would be my donor car if I do decide to go ahead. Problem is, these days I don't have the time, space or facilities to swap engines over myself ... I might have a word with a couple of local garages to see how much they'd want for doing the bulk of the work... how long do you reckon it would take a proper garage to carry out the full conversion to an M20 - enginge + gearbox, suspension, diff, rear discs etc? would I run into any problems using a convertible as my donor car?
Post Sun Oct 29, 2006 4:13 pm
eamo wrote:you'll also need an oil cooler and the engine loom
These would normally come with the donor!
Personally, I wouldn't worry too much about the oil cooler. Engine oils have come a long way since the E30 325 was designed. The M20B20 was deemed to be OK without one, and the M50B25 doesn't have one either, s any oil cooling requirements must be marginal.
bazman
Post Sun Oct 29, 2006 4:21 pm
More pros ad cons then, still up for it if I can find a decent donor!
Thanks again guys. :cool:
