gear indicator lights gone out on my auto.....
dom-1984-320i
Post Fri Oct 27, 2006 12:17 am
The lights on my autobox have gone out, the orange one's that indicate which gear you are in. i have the gear numbers on both sides of mine, i have not seen another e30 auto with them on both sides, normally just on the drivers side. i am guessing there are small bulbs under the casing, would i be right and if so are they easy to first get to and then replace? Yes i have checked the fuse's incase your are wondering and all fine.
as ever any help would be much appriciated.
Post Fri Oct 27, 2006 12:27 am
The light is fixed to the selector lever and moves with it.
The wires to the lampholder bend every time the lever is moved, and eventually break internally. Could also be just a fused bulb of course.
dom-1984-320i
Post Fri Oct 27, 2006 10:49 am
cheers Brian, am off to check now!
dazleeds
old skool raver
old skool raver
Post Fri Oct 27, 2006 10:53 am
mine used to come on and off at will
prob as brian says when you shifted the wires would bend and it would go off but then come back on when in neutral :roll:
www.oldskoolfantasy.co.uk
dom-1984-320i
Post Fri Oct 27, 2006 8:53 pm
I found the problem, just a blown bulb, but where can i get a replacment from, there tiny! Went to Halfords as there is one pretty close, but none there. Any susgestions?
andyp
True Old Skooler
Post Sat Oct 28, 2006 2:37 am
any car shop will have them mate, go to alphas at drayton pk
Post Sat Oct 28, 2006 10:07 am
Local BMW dealer.
