The lights on my autobox have gone out, the orange one's that indicate which gear you are in. i have the gear numbers on both sides of mine, i have not seen another e30 auto with them on both sides, normally just on the drivers side. i am guessing there are small bulbs under the casing, would i be right and if so are they easy to first get to and then replace? Yes i have checked the fuse's incase your are wondering and all fine.
as ever any help would be much appriciated.
gear indicator lights gone out on my auto.....
dom-1984-320i
The light is fixed to the selector lever and moves with it.
The wires to the lampholder bend every time the lever is moved, and eventually break internally. Could also be just a fused bulb of course.
dom-1984-320i
cheers Brian, am off to check now!
dazleeds
- old skool raver
mine used to come on and off at will
prob as brian says when you shifted the wires would bend and it would go off but then come back on when in neutral
www.oldskoolfantasy.co.uk
dom-1984-320i
I found the problem, just a blown bulb, but where can i get a replacment from, there tiny! Went to Halfords as there is one pretty close, but none there. Any susgestions?
andyp
- True Old Skooler
any car shop will have them mate, go to alphas at drayton pk
Local BMW dealer.
