There are alot of small (and not so small) scuff marks on the seatback panels of my new set of sport seats. I thought a good clean and poilish would remove them but they are still visible.
Does anyone have any tips on how to remove or disguise these?
Thanks,
Kevin
How do you remove scuff marks from seat backs
willow
I have those scuffs too, and on the bottom of the drivers' door card. I haven't been able to get rid of them either so any suggestions would be great!
Save the E30s!
johnono
scuff marks? do u mean actual abrasion to the seat back or just marks from shoes that dried out and left a mark?
willow
They're like black marks left by shoes kicking the back of the seat or door cards.
Save the E30s!
johnono
sewing machine oil, and a towel
should losen the dirt in the grain, and smooth the surface and give it a juice at the same time
kevin316i
I'll give it a try, as new ones are priced at Ԛ┚¬85 + VAT each in Ireland!
Kedge
What about scuff makrks Johnono
johnono
depends how bad dude
if theyԚ´re really gouged then itԚ´ll be harder, mabey a plastic filler (?) or melting a (this will sound weird) a coloured glue gun stick
and smoothing it with a wet finger
i fpml as i write this , thinking `yeah, whos gonna do that
Ԛ´
if its not to serious then try a iron against folded foil, to press the scuff in on itself, other than that, i would prefer a new pannel.. or a stiff drink
kevin316i
Some marks are more like gouges than scuffs, so I guess some sort of filler is in order here. I know you can get special fillers with leather restoration kits, but probably expensive. Guess I'll start with the small ones and work my way round.
marchad
you know i had that problem too
you can use a rubbing compound. it takes it right off. i figured it out on accident. but yeah it works
Globulator
Woolies leather colour stuff can hide a world of damage pretty convincingly..kevin316i wrote:Some marks are more like gouges than scuffs, so I guess some sort of filler is in order here..
..you might want to make girls take their shoes off at the door next time,
stilettos eh - better check the headlining too!
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
poppit
Try a paint stripper heat gun, but dont hold it to close cause you will
melt the plastic.try it on something else first!!! it does work, just take your time.
