Rear axle carrier bush lubricant
SGP
Post Thu Oct 19, 2006 9:39 pm
I am hiring a special tool to remove and replace the above bushes. According to the tool hirer I should get a bmw lubricant/sealer called circalite which once dry bonds the bush into the carrier.Does anybody have the part no. for this?My local dealers parts dept are not very helpful.
Thanks.
If it ain't broke..
Fix it till it is :)
stuartgallafant
Post Thu Oct 19, 2006 9:42 pm
you can use red grease too, which i believe is very similar stuff. however, fairy up liquid has the same effect! just heat up the carrier, cover the bush in fairy washing up liquid, press the bush in, and the heat from the carrier will burn off the washing up liquid without damaging the bush
SGP
Post Fri Oct 20, 2006 11:04 pm
Appreciate your advice Stu,but would still like to get the right stuff if it even exists,which I doubt.The idea of a product that actually welds the bushing to the carrier appeals to me and seems like something that BMW would think of !
If it ain't broke..
stuartgallafant
Post Sat Oct 21, 2006 4:19 pm
it doesnt actually do what this guy is suggesting! it merely allows lubrication into the carrier, and then dries up all tacky, so that the bush wont move. but, when the whole setup is put together, it wont move anyway
if it were to actually 'weld' it to the carrier, you'd have a bastard of a job trying ot get it out again...
HTH
SGP
Post Mon Oct 23, 2006 2:41 pm
Fairy Liquid solution it is so , thanks.
If it ain't broke..
stuartgallafant
Post Mon Oct 23, 2006 9:04 pm
no worries :wink:
