m30 conversion engine mounts!!!UPDATED PICS FIRST lot made..
Karan
i am having some m30 conversion mounts made at the moment as copied from some e30.de mounts i bought.....
i will have a price by this evening and post it here..
could anyone who is interested please post here and let me know
they are VERY high quality (i bullsh1t u not) 5mm sheet steel, not alloy ones like normal e30s.... in fact they are overkill and way stronger than the actual subframes on the e30 probably..
so please post here and let me know.... they are Ԛ£160 from e30.de in germany but they will hopefully be half this price and exactly the same..
cheers
karan
cheers
karan
Ant
- Retired Team Member
Good effort Karan !
Stickied for 7 days ..
I've also added this to the e30tech BB in the US , might get a few more bodies, worth a shot
Email FTW
Davenotouring
Nice work mate.
I'll be taking a set off you in preparation for summer conversion.
BMW 328i Cab - Daily Slag
Ritchie
Nice 1, i will take a set asap. I was gona order a set from fritzs bitz next week.
Karan
unfortunatelty no luck with the first place-too pricey, more than the e30.de ones...
gonna try a couple more prices as i really dont know why more people arent doing what really is a cheap and well documented conversion, so if we could get a provisional list up for buyers, so i can get cheaper costing on more buyers that would be great, so
1. Dave
2. Ritchie
im not gonna lie this is not gonna happen overnight.... but they will be of the best quality and i wanna get the heapest price possible, its silly to buy mounts that cost more than a e34 m30 lump...
more news will follow tmro....
thanks for the sticky ant, would be great if u could keep it here for a few days then move to the group buy section-cheers dude
cheers
Karan
1. Dave
2. Ritchie
cheers
Karan
Andy335Touring
Nice one Karan,just thought i'd add a picy of the E30.de mounts
Karan
cheers andy
proper kit this is!
proper kit this is!
Karan
ok back with a first price....
they are gonna be Ԛ£110 for a pair, not as cheap as i initially thought they were gonna be....but still a Ԛ£50 saving, i will try a couple other places and see what they say..
note the Ԛ£110 mounts will be made in 10mm steel, from this first place i got a quote from....
will try a couple other places and let u know soon...
Karan
Karan
Davenotouring
Karan....sideways on the hunt for bargains!
Good lad!
Good lad!
Jos
What engine position are they for?
Might be interested in these as well if the price is good.
'94 e36 tree climber
Karan
hello jos, the mounts can be used in positions 2 or 3, although to anyone doing this comnversion id recommend position 3 every time....
position 1 (the futhest forward can noy be used with these mounts
the m88 and s38 engines like i am using can also be used with these mounst as the block mounting points are the same!
as i said the first price i have obtained is for Ԛ£110 for a set.. but i will check a couple other places and see what they say, if not it will be the Ԛ£110 ones in 10mm steel
hope that helps
Karan
hope that helps
Karan
Moofles
bet he's great in the january salesdavetouring wrote:Karan....sideways on the hunt for bargains!
Good lad!
'08 GSX-R750, '02 CBR600F, and a beast of a Focus 1.8LX...
My old sig
- http://img52.imageshack.us/img52/2652/funnyface8eg.gif
My old sig
Kedge
How important are these for the conversion, are there anyothers ounts out there or do you have to have these made regardless?
Dave
Dave
Karan
u have to have some sort of mounts made reagrdless....
rs4pro3
I'd be interested if they were cheaper then the e30.de mounts(which I already have). Are these for the Early or Late M30 blocks?
Karan
they will fit all i think.... will find out and let u know.. although i beleive all block mounting points on m30s are the same...
cheers
Karan
cheers
Karan
Karan my uncle does this sort of stuff fabrication and welding he's a tool maker. If i had one of these i could take it to him and see what he says? not sure how much his price would be but i'm sure it would be competitive!
PS my dads a grinder so anyone who needs a head skimming PM me!! or blocks for your 2.7's
Karan
ive had offers from the resident holy man jesus too..... but im gonna check local options out first... or ill take one off you 2 up on the offer for sure! cheers guys
Karan
Karan
Toby_Unna
- Boost Junkie
sadly not the case. i know this because i've swapped my e30 from early to late engine.although i beleive all block mounting points on m30s are the same...
e30.de make different mount sets for early and late block engines. the left (passenger side on RHD) mount can be designed to fit both blocks, but the right one is different between early and late blocks, the mount holes are different. might be possible to design it to fit all blocks by incorporating extra bolt holes that would only be used on one type.
by early i mean e28 m535i/635csi/e23 735i etc.
late is e32 and e34 m30s.
not 100% sure which blocks the e28 and e34 m5 engines used...
Jos
Got a friend of mine who is a professional fabricator/welder, I think I will get him to do mine, they won't be designed/ready for your conversion Karan, but I am sure I can get him to make them for the price of materials and a bottle of red wine for other conversions later in the year.
Karan
thanks for clearing that up toby!Toby_Unna wrote:sadly not the case. i know this because i've swapped my e30 from early to late engine.although i beleive all block mounting points on m30s are the same...
so these will be for the later type blocks in position 2/3
the e34 lump is best suited to the conversion anyway
Karan
adil325i
hi karan,
could these mount the s50 engines too? if so, u can count me in.
cheers,
adil325i
cheers,
adil325i
Karan
no they wont......
but the standard e36 m3 arms with e28 rubber mounts will do for ure conversion,,,,,,,
u dont need special mounts for that application,,,
u lucky sod!!
Karan
u lucky sod!!
Karan
gorgeee
id have some later in the year
Black Sport
Karan
ok ive finalised the price at Ԛ£110 or Ԛ£120 posted....
PM me if u want them.. so far i have:
1.Ritchie
2.Dave
i'll be putting them in on monday.... so should hopefully be done by the following weekend.
cheers
Karan
1.Ritchie
2.Dave
cheers
Karan
Karan
ok first 2 sets are made for dave and ritchie.... if anyone else wants any...
heres some pics... much neater and now 10mm steel!: here they are on my s38 lump!
echaust side:
inlet side:
check out the girth on these bad boys....
any more takers please PM me...or post on here....
cheers
Karan[/img]
echaust side:
inlet side:
cheers
Karan[/img]
Davenotouring
Loving the girth mate.
Can't wait to get the 3.5 sat on those bad boys.
Moofles
you have a large girth there karan
My old sig
My old sig
glenn
- Engine Transplant Services
fook me, do you think they are going to be strong enough !!!???
Karan
any more takers..... one of the few sources for mounts here in the UK without going to ripoff merchants who i will not name.....
cheaper and better than the e30.de ones
gorgeee
ill have some once i get a m30 for my car
Black Sport
325icoupe
hi, i am also thinking of going the 3.5 route this summer, how soon would u need confirmation of wanting the mounts and getting the cash?
Karan
as soon as possible as i will soon no longer have a template to make em from325icoupe wrote:hi, i am also thinking of going the 3.5 route this summer, how soon would u need confirmation of wanting the mounts and getting the cash?
Karan
anyone else want these.....
if so please mail me at hp3899@bris.ac.uk
could mods please let this rn for a couple of days.... then move it to group buys please.... as its been running for ages now LOL
cheers
Karan
cheers
Karan
azzkikr
Could you post the specs on the mounts? What dimensions you can measure. I want to get some made here in the US so I dont have to pay to ship heavy steel across the pond. I have a buddy in a machine shop here and he said he could make them for $50 US if I could just get the specs.
