e30 m30 with stromung exhaust
devinwwu
Post Fri Oct 06, 2006 8:07 pm
http://video.google.com/videoplay?docid ... 2048849708
just finished it up!!!
dual 2" all the way back with magnaflow dual in dual out cat. I'll probably put in cutouts later just for fun but we'll see... exhaust rear section is a e30 m3 section from understeer.com
enjoy!
Andy335Touring
Post Fri Oct 06, 2006 9:00 pm
Nice ! 8)
Get some more pics up of your swap if you can
This is my 335 with a Scorpion M3 exhaust, no cat
http://homepage.ntlworld.com/a.law47/1.AVI
devinwwu
Post Fri Oct 06, 2006 9:07 pm
devinwwu
Andy335Touring
Post Fri Oct 06, 2006 9:13 pm
devinwwu wrote: Image
I like this one ! :lol: :rock:
gareth
Post Fri Oct 06, 2006 9:21 pm
i'd be worried that those stones might slip out and you'd have a very lowered E30!!!!
dan_emaps
Post Sat Oct 07, 2006 4:23 pm
nice!! but your poor car was stone cold! 8O
jmc330i
Post Sat Oct 07, 2006 4:34 pm
Sounds nice 8)
But are you sure its a full size E30??? 8O :lol:
dan_emaps wrote:nice!! but your poor car was stone cold! 8O
I doubt the temp guage (or sensor) was wired up as it didnt move when the ignition was turned on.
James
'91 325i Sport
'93 318i touring 16v
ed325i
Post Sat Oct 07, 2006 6:31 pm
looks good and sounds good to 8)
Where did you get the front top mounts from ?
m10man
Post Fri Oct 13, 2006 12:40 pm
Nice one mate! That is obviously a 325e tacho - I would be getting myself an i tacho so I knew exactly where I am. I feel sorry for you blokes having to run cats too :(
devinwwu
Post Mon Oct 16, 2006 11:16 pm
ya
cat's aren't too bad but the few extra horsies wouldn't hurt...
in terms of temp the car had been warmed up, the temp gauge doesn't work and i'm still trying to figure that out.
until then i'm running the heater full blast with my electric fan on over-ride with a switch.
THanks for the comments!
gareth
Post Tue Oct 17, 2006 12:00 am
devinwwu wrote:in terms of temp the car had been warmed up, the temp gauge doesn't work and i'm still trying to figure that out.
have you tried a M20 temperature sender? the M30 one won't work with the M30 loom in a E30. the connector is the same though so it's a 5 minute job to simply swap them over.
devinwwu
Post Tue Oct 17, 2006 12:35 am
tried it and i actually have a full thread going in this forum about it too.
i do have one question though. I have a fuel cut issue. when just revving and such its fine but ocassionally when i try to floor it, the car will seem like it goes into fuel cut and the car hesitates real bad.
anyone else had this issue or have ideas????
gareth
Post Tue Oct 17, 2006 7:44 am
the only similar thing i've had was due to duff rotor arm, cap and leads, well i replaced tham all at the same time and that cured it.
DaveD
E30Zone Wiki Specialist
Post Tue Oct 17, 2006 2:01 pm
just a quick question, when you put the magnafow in you cut out the old cat and if so did you add any extra silencers(mufflers) in the mid section...got a magnaflow same as yours somewhere in the post from texas
devinwwu
Post Tue Oct 17, 2006 4:25 pm
i didn't add any extra ones no. i put in the stromung rear section from the e30 m3 from understeer.com the whole system is dual 2".
I just replaced cap, rotor, plugs and i'm using the coil from my e34. I'm going to try the e30 coil tonight maybe.
Could this be fuel related??? rather than spark
DaveD
Post Tue Oct 17, 2006 5:13 pm
got a scorpion bbox on mine and wondered if it was going to be too loud without extra silencing...thanks
DRIFTBOY
Post Tue Oct 17, 2006 5:24 pm
I'm using a scorpion backbox on it's own on my 335i.
It is LOUD!
You wouldn't get on most track days with it!
I'm personally not liking the sound that much either, hasn't got the nice growly roar I was expecting. Just a load of noise!
DaveD
Post Tue Oct 17, 2006 5:48 pm
quite quiet on my 325 just a nice burble but i have a cat so it might make a difference
oze30
Post Tue Oct 17, 2006 6:08 pm
Have you got any more piccs on the torque bar?
Pal318is
Post Tue Oct 17, 2006 6:19 pm
Very Nice Pic's and your exhaust sounds sweet :thumb:
Well Done :rock:
Pal
Pal
Image[img]http://Image
devinwwu
Post Wed Oct 18, 2006 8:10 am
thanks guys. any ideas on the fuel cut issue??
oze30 let me know what you want pics of and i'll see if i have it. its just the ireland engineering 25mm front and 22mm rear sways
DaveD
Post Wed Oct 18, 2006 11:41 am
fuel filter ..pump on the way out..injectors blocked,,,plug leads
devinwwu
Post Wed Oct 18, 2006 5:00 pm
filter is brand new, pump may be an issue, injectors have only been in for 5k mi. leads i'll have to check.
on a side note my fuel level gauge was at about 1/3 tank and i was on the freeway doing 60 and it all of a sudden started rising up to full. got to full tank then stayed there for a little bit, then dropped down slowly to half tank. by the time i got to work it was at 1/3 again???
any ideas
devinwwu
Post Thu Oct 19, 2006 12:27 am
i had another thought. if you look in the 5th picture at the set of spark wires off the "dizzy" cap you can clearly see a sensor that goes around one of the leads. I am not worried about which one cause the old one is still there but it broke off.
first, what is this sensor for and
second, would it cause the engine to fuel cut or hesitate really bad on harder acceleration.
Thanks guys!!!
i plan to get it put on either way i just need to know what it was
