Rolled Arches???? BORBET
beem
Post Wed Oct 11, 2006 10:56 am
HI guys im buying a set of Borbet A's 7.5x16 front and 9x16 back. will the arches need to be rolled at the back for the 9's to fit????
ste
Post Wed Oct 11, 2006 12:02 pm
Unless you have it at 4x4 height your rear arches will need pulling.
dazleeds
old skool raver
old skool raver
Post Wed Oct 11, 2006 12:05 pm
hmmm interesting
im getting 7.5x16 borbets today but am also after a pair of 9inch rears or maybe 8.5 either will do
but have also had new rear arches fitted recently so really dnt wanna start stretching arches etc
when you say pulling arches what exactly do you mean??
does this damage paint at all?? or can it be done without any damage??
Daz
www.oldskoolfantasy.co.uk
beem
Post Wed Oct 11, 2006 12:53 pm
I was hoping i wouldnt have to get them rolled :( ive read on other forums that paint can be damaged.
MadE30mike
Post Wed Oct 11, 2006 1:53 pm
My mate just got these wheels for his Polo GTI which luckily was slamed on coilovers, with these wheels hes had to raise it higher than standard spec lol he aint a happy chappy :x
kunjani
Post Wed Oct 11, 2006 2:07 pm
phoned just matz, who build custom bbs for e30's and the guy told me that you can safly go to 8.5 on the rear for e30
but thats more than i thought youd be able 2, i know 8 works for a fact
beem
Post Thu Oct 12, 2006 1:02 am
S**T im in trouble then ive ordered a set of 9's for the back! Il just have to get them rolled i guess :(
benjy
Post Thu Oct 12, 2006 9:05 am
I'm running 9X16 borbet A's on the rear of my iS, i'm using 215/45/16 tyres with a 40mm H&R cup kit and the inner lip has been fettled a little. Altho it is rubbing very occasionally, that is down to rear top mounts beenin shagged!! I shud be fittin e46 cab ones today.......i'll let you know how it goes 8)
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
liam012
Post Thu Oct 12, 2006 10:14 am
kunjani wrote:phoned just matz, who build custom bbs for e30's and the guy told me that you can safly go to 8.5 on the rear for e30
this may be true - but not for every offset - sure you might get 8.5 on with oem offset but anything down around 20mm or 15mm will rub ur arches
i had et20 borbiett A's which were 7.5 and they rubbed when loaded down or giving it 50mph through twisty stuff.
beem
Post Thu Oct 12, 2006 1:44 pm
benjy wrote:I'm running 9X16 borbet A's on the rear of my iS, i'm using 215/45/16 tyres with a 40mm H&R cup kit and the inner lip has been fettled a little. Altho it is rubbing very occasionally, that is down to rear top mounts beenin shagged!! I shud be fittin e46 cab ones today.......i'll let you know how it goes 8)
What tyres are you running on the front? size?
benjy
Post Thu Oct 12, 2006 2:17 pm
Fronts are now 205/45-16 toyo's and the rears are 215/40-16. Ive had no rubbing issues with the front and they are ET20, Not totally sure but i think the rears are ET15. Now fitted new E46 cab rear top mounts and it only rubs over really bad bumps but even then its only just a touch, The tyre doesnt have any real damage at all...
i totally recomend the H&R cup kit, feels nice and solid but without being harsh or slamming over bumps, nicly controlled i would say. 8)
MadE30mike
Post Thu Oct 12, 2006 2:31 pm
benjy wrote:Fronts are now 205/45-16 toyo's and the rears are 215/40-16. Ive had no rubbing issues with the front and they are ET20, Not totally sure but i think the rears are ET15. Now fitted new E46 cab rear top mounts and it only rubs over really bad bumps but even then its only just a touch, The tyre doesnt have any real damage at all...
What drop did you go for? 35mm or 60/40mm ?
benjy
Post Thu Oct 12, 2006 5:14 pm
60/40 drop. Been out for a run this arvo and it only rubs over bad bumps now, well chuffed!! A big cheers to eko for the help doin the top mounts earlier :wink: . HTH
beem
Post Fri Oct 13, 2006 1:29 pm
Sonds sweet then..your arches are totally standard right? has anyone any opininions of the new KW suspension set up??
benjy
Post Fri Oct 13, 2006 3:26 pm
Arches are standard apart from havin the lip inside "folded" out the way.
