Yet Another 335I! ... Now With Turbo
gareth
Post Mon Oct 09, 2006 8:33 pm
DRIFTBOY
Post Mon Oct 09, 2006 9:06 pm
Sorry - only joking! :)
They just get you feeling like you hate them sometimes, don't they?! :-x
Still had it easily wheel-spinning in 3rd gear in the rain this morning though! winkeye
bigdek
Post Mon Oct 09, 2006 9:58 pm
nick those injectors should be fine.
i bought them off andy335touring. he had them ultrasonic cleaned.
as for the poor fuel economy.
lift your right foot slightly 8)
they are piss poor on petrol though regardless
gareth
Post Mon Oct 09, 2006 11:01 pm
bigdek wrote:they are **** poor on petrol though regardless
tell me about it :( :twisted:
DRIFTBOY
Post Tue Oct 10, 2006 1:03 am
If my trip meter on the speedo is accurate then my last tank of fuel gave me 20.4 mpg.
I was really chuffed with that as my previous car struggled to do better than 12mpg! So :D
nickso
Post Tue Oct 10, 2006 4:51 pm
bigdek wrote:nick those injectors should be fine.
in that case im just going to turn up the stereo derek :D
the noise is really pissing me off but like i said if its serious another cheapo 535 is never far away.
it would clearly be madness to lift my right foot in the quest for fuel economy :twisted:
the cruise control helps a lot if im just piddling about town though....if my obc is to be believed im averaging 26 between cruise control and thrashing the life out of it....not bad i thought but i think it will do better once i stop it running rich.
'88 e30 328i M52 track bint.
gareth
Post Tue Oct 10, 2006 8:23 pm
this is one of the only places in the world where we can be happy to get over 20mpg!!!!
DRIFTBOY
Post Tue Oct 10, 2006 8:25 pm
I bet the Pontiac Firebird forum dudes can only dream of such economy!!! :teehee:
m10man
Post Fri Oct 13, 2006 12:19 pm
Man, it is depressing seeing the trouble you are having mate. Any luck with sorting it out yet? You said your chip arrived - what did you get and what did it cost? I am looking at a chip from Germany at the moment. I still dont understand the reports about bad fuel economy some of you guys are experiencing - I am consistently getting around the 28mpg out of mine. Admittedly most of my driving is highway and 100km/h speed country roads and I find I dont have to give it much accelerator to do the legal speeds, but I also enjoy a few spirted bursts along the way.
DRIFTBOY
Post Fri Oct 13, 2006 12:31 pm
This week I've compression tested it and closely inspected the camshaft lobes and all seems ok there.
My chip is from Sal at the Zone shop, cost Ԛ£85 and certainly made a good difference. When I've got it running better I'm sure the difference will be even greater.
My fuel consumption is usually bad, I do lots of short journeys as I only live 7 miles from work! I haven't done any very long trips since I've been measuring my mpg.
I'm going to try changing the temperature sensors and check my camshaft timing this weekend. Might try another fuel pump too.
m10man
Post Fri Oct 13, 2006 12:45 pm
If you have put a custom cam in it just could be your cam timing. Did you have any amount shaved off your block or head? The E34 heads are very sensitive to having anything shaved off them - you may need an adjustable cam sprocket.
Oh and by the way - do you get any sleep? Everytime I check on the zone you are logged in. :sleep: even when none of the other UK guys are online.
DRIFTBOY
Post Fri Oct 13, 2006 12:51 pm
I did have a tiny amount taken off the head, not to deliberately increase compression, just to make sure it was flat and no more.
I didn't realise adjustable camshaft sprockets were available for the M30 engine! Where can I get one?
m10man
Post Fri Oct 13, 2006 1:05 pm
Korman BMW in the US. Here is the link http://www.kormanfastbmw.com/e34m30.htm
DRIFTBOY
Post Fri Oct 13, 2006 4:01 pm
Interesting link!
Thanks m10man! :wink:
m10man
Post Sat Oct 14, 2006 12:18 am
No problem mate. Looking forward to hearing how yours goes when it is all sorted :cool: .
DRIFTBOY
Post Sat Oct 14, 2006 12:22 am
Me too!
I get another grey hair every time I think about it!!! :cry:
I'm sure I'll get it sorted soon. Hopefully in time for a quarter mile session at Santa Pod before the last one of the year!
DRIFTBOY
Post Sat Oct 21, 2006 10:11 pm
I've been the luckiest bloke in the whole flippin' world!!!
I decided today to check my camshaft timing.
When I built the engine the timing marks / bolts didn't quite line up, either slightly out of line one way or on the next tooth along slightly out the other way. So I guessed. :roll:
Today I moved it to the next tooth round.
Idle is now smooth, it pulls like a train winkeye and no longer rattles like the valve clearances are too big.
This can only mean one thing (and a local engineer who I know well and who has built M30s before agreed), that my rattle was valves touching pistons! 8O
I have been revving this to 6000+ rpm regularly and have done 800 miles like it! And no signs of damage at all!
Anyone want me to time up an M30 for them ? :mad:
Got to find out when the next run what you brung day at Santa Pod is now!! :D
Andy335Touring
Post Sat Oct 21, 2006 10:18 pm
Well done dude, i'm chuft you've got it sorted and pulling as well as you hoped it would.
Mine was the same, go for one tooth and it's slightly out then go for the other and it's still not quite right :?
Makes me wonder about mine :eek:
Andy335Touring
Post Sat Oct 21, 2006 10:20 pm
It also makes me think that an adjustable cam pully might be a good idea and weather having the head skimmed thows the cam timing out, my head is still in spec thickness wise and i've used the thicker head gasket ?
DRIFTBOY
Post Sat Oct 21, 2006 10:25 pm
Thanks dude!
You'd know about it if it was wrong!
Sounds horrendous and the engine really shakes on idle. And it's a pig to drive in traffic.
Am I right in thinking you are using a Schrick 284 camshaft ?
I wonder if that throws the timing marks out a bit. ?
I'm very relieved!
Can't wait to give it a proper test drive tomorrow! winkeye
DRIFTBOY
Post Sat Oct 21, 2006 10:28 pm
Yeah I had a tiny bit taken off the head, just to make sure it was flat. Could be that. Didn't know you could get thicker head gaskets! Who does those ?
I've seen a link to an American site who do adjustable pulleys, I'll try and find it if you don't have it.
Andy335Touring
Post Sat Oct 21, 2006 10:47 pm
Yeah, a 284, it could be the cam i guess ?
You can get them from the dealer for about 80 quid or like me order it from ECP for about 45 quid. Standard gasket is 1.7mm compressed and the thicker one is +0.3mm.
I've got it cheers, it's where i got my cam/springs/rockers/spring retainers from, it was the only place i could find at the time.
DRIFTBOY
Post Sat Oct 21, 2006 10:54 pm
Cool.
There is a run what you brung at Santa Pod next weekend!
If it isn't raining - I'm there! :D
Anyone else up for it ?
Andy335Touring
Post Sat Oct 21, 2006 10:56 pm
I'm trying to save some money other wise i'd be up for it
DRIFTBOY
Post Sat Oct 21, 2006 11:00 pm
No worries.
Signing off for now, got a fed (with me always working on cars and being on the zone) up girlfriend to go and mend! :roll:
Andy335Touring
Post Sat Oct 21, 2006 11:04 pm
what kind of "mending" ? winkeye
m10man
Post Sun Oct 22, 2006 12:34 am
Damn you're LUCKY!! :eek: That is terrific news though that now it is right! Sounds like an adjustable cam gear is the go on the Schrick cam then - I will have to remember that when I put mine in.
DRIFTBOY
Post Sun Oct 22, 2006 1:01 am
Andy335Touring wrote:what kind of "mending" ? winkeye
Not that kind tonight! Just a bit of attention!
My back really aches from bending over doing the engine (I have a history of back issues). If the bonnet opened the right way it wouldn't be quite so bad. I'm quite crippled now!
Thanks m10man!
Adjustable does seem a good plan.
I wonder if you can get to the adjusting bolts just by taking the rocker cover off. If it's a radiator out job every time you adjust that would be a right pain!
gareth
Post Sun Oct 22, 2006 3:18 pm
you lucky git!!!!
i've had the same thing once with big inlet valves and a rally cam in a MK2 RS2000. it left little shiny marks on the pistons but didn't damage anything! :eek:
i modified the pistons for a but more clearance!
the cam had 13.3mm of valve lift and a 322 degree duration! :cool: that and a severely skimmed head (17:1 compression) and +2mm inlet valves, it was going to happen wasn't it!!!
DRIFTBOY
Post Sat Oct 28, 2006 9:31 pm
Just an update!
As some of you following this thread might know I bought a G-Max -60mm suspension kit from a fellow zoner recently. I got it fitted this week and so far I'm quite impressed. The car looks so much better at it's new ride height and it is now level! It is a little stiffer than the other Dutch crap I got off Ebay but isn't too harsh for me on bumpy roads, for myy preferences it's just about right. :D
While I was at it I fitted it with E46 rear top mounts from BMW.
Also looks like I've sorted my oil leak tonight. I had a slighly leaky oil pressure switch and I was a bitt too cautious when I bolted the sump on not to crush the gasket. I tightened the sump bolts a little and it seems ok so far! :D
Today I also ordered Powerflex rear beam bushes (one of mine is clunky) and a set of Powerflex trailing arm bushes. Then the back end will be just about sorted.
All in all a productive week and weekend for me! :D
Here's what it looks like now -
Gareth - if your'e still thinking about getting a G-Max kit I could come down and take you for a spin sometime if you wish.?
gareth
Post Sun Oct 29, 2006 7:55 pm
cheers, i may take you up on that offer as and when i'm in a position to make more progress! :D
glad yours is coming along a bit better than recently!
DRIFTBOY
Post Sun Oct 29, 2006 8:01 pm
Thanks! And no probs, just let me know when you want a ride!
I've been busy today too.
I painted those kidney grilles - that you kindly donated me - black and fitted those, changed the oil and filter and fitted a new stereo head unit as the one that came with the car refused to play cd's.
I've got a week off work in november so I want to get lots more done then too.
And get myself into a bit more debt at the same time!!! :?
gareth
Post Sun Oct 29, 2006 8:07 pm
always the way! :D
DRIFTBOY
Post Sat Nov 04, 2006 9:24 pm
I went to my local BMW dealer today to get a few little bits and pieces (nothing exciting!).
One of the bits I wanted was a pair of strut top bearing dust caps (the little plastic push in ones under the bonnet).
There are apparently two types so the parts bloke said he'd come and measure which one I needed.
When he opened the bonnet, the look on his face was a picture!
It went from confusion, to disbelief, to amusement!
Priceless! :teehee: :teehee: :teehee:
euan
Post Sun Nov 05, 2006 8:58 am
just read this from start to finish what a great conversion and a great end result well done matey ill be in the same position soon when i start my c reg 735 into my f reg 318
