i can remember reading about not using early ETA lumps, but can nt think what the reason was , can any one rember whats wrong with them/ what to look for ?
85, or 86 ETS LUMPS
exup
- Boost Junkie
Hi
liam012
if you just search for "eta" then you will have a good days reading.....
between forum faq and usergroups above....
Big hole in the end of the block, IIRC.
Templ8e30
Yep, there is a large core plug at the back (gearbox end) of the block.Brianmoooore wrote:Big hole in the end of the block, IIRC.
The problem with them is the weaker bearing caps apparently
Cheers,
Iain T
2007 Mazda 6 2.0 estate
