85, or 86 ETS LUMPS
exup
Boost Junkie
Post Sat Oct 07, 2006 8:24 am
Hi
i can remember reading about not using early ETA lumps, but can nt think what the reason was , can any one rember whats wrong with them/ what to look for ?
:x
:twisted:
liam012
Post Sat Oct 07, 2006 10:08 am
if you just search for "eta" then you will have a good days reading.....
between forum faq and usergroups above....
Post Sat Oct 07, 2006 10:27 am
Big hole in the end of the block, IIRC.
Templ8e30
Post Sun Oct 08, 2006 8:35 am
Brianmoooore wrote:Big hole in the end of the block, IIRC.
Yep, there is a large core plug at the back (gearbox end) of the block.
The problem with them is the weaker bearing caps apparently :mad:
Cheers,
Iain T
2007 Mazda 6 2.0 estate
