e28 diff
johnl320
Post Mon Oct 02, 2006 7:49 pm
got the chance for a 525e e28 diff for my m30 conversion, anyone got any ideas what ratio they are or a link to somewhere that can help
cheers
john
Beemer Redeemer
Post Tue Oct 03, 2006 9:31 am
Well it depends on what year it came from. But EPC shows the ratio could be either 2.93 3.07 3.46
James
johnl320
Post Tue Oct 03, 2006 6:05 pm
Its on an E plate, if thats any help, Where did you find the ratios??
john
Post Tue Oct 03, 2006 10:46 pm
pretty sure it'll be 2.93.
johnl320
Post Mon Oct 23, 2006 1:10 pm
Got the diff today, it was a 3.07, that'll do me. thanks for the help gents
john
Toby_Unna
Boost Junkie
Post Mon Oct 23, 2006 1:55 pm
mine is a 3.08, says so on the tag anyway?
a bit long for a stock m30 but it will still go well and cruise really nicely. a few engine mods will soon make it go better :D
exup
Boost Junkie
Post Mon Oct 23, 2006 8:50 pm
for ref
I ve had 3 525e now
one 87 =3.07
one 88 =3.07
one late 88 =2.93, i think its only the very late 88 /89 525e got the 2.93 , dif, and they all had an easy lift too, as they don t rev past 4.5 revs
johnl320
Post Mon Oct 23, 2006 10:08 pm
Toby_Unna wrote:mine is a 3.08, says so on the tag anyway?
Its got an E28 dogleg box Toby so it still may be a bit short.
john
EOS
Post Tue Oct 24, 2006 7:16 am
Hi is a E28 diff straight fit onto a E30? Also what other models can you pinch diffs from that go straight on? With those ratios mentioned above?
Post Tue Oct 24, 2006 8:51 am
E28 MEDIUM case diff will fit straight on an E30 with a change of output shafts and rear cover for the corresponding items from a medium case E30 diff.
Toby_Unna
Boost Junkie
Post Tue Oct 24, 2006 10:39 am
john
aha that'll be ok then. pretty much identical gearing to what my m535i had, about 135-140 flat out at 6k with 205/50/15s, more if you put bigger wheels on.
perhaps a touch short as you say but you'll certainly go well off the lights :D
johnl320
Post Tue Oct 24, 2006 7:51 pm
john
I'm gonna see what its like then maybe experiment with slightly higher profile tyres,I know its not ideal but when you're on a budget of about 20 quid a month its all about compromise. I still need a rad and prop as well. Cheers for the help fellas.
Heres a couple of photos of the chrome turd 316 carb beast ready for conversion. Don't worry all the running gear ARBs etc have already been uprated.
john
Toby_Unna
Boost Junkie
Post Tue Oct 24, 2006 10:55 pm
johnl320 wrote:Don't worry all the running gear ARBs etc have already been uprated.
john
i don't worry too much about things like that :lol:
nice wheels, nice colour :cool:
