bbs centres...sorry if this is daft question....please help.
muleskinner
I bought some stonking 15inch BBS 15inch alloys of fellow zoner , spadge ( top bloke ) , but i have bought 4 bbs centres to fit the wheels of an ebay seller.
does anyone know if there is a knack to fitiing these things or can anyone confirm the correct bmw part number , because I cant get them to fit.
oh and what does the small arrow on the centre mean.
They look like 15 inch centres and bbs in appearance.
cheers
mule.
cheers
mule.
Chris-W
domross
Should just fit over the centre of the wheels and then twist to lock into place...
jmc330i
Can you post a pic of them (both sides)? Should be able to tell if they are genuine.
As was said, they push on and the centre (nut shaped bit) twists until its locks on.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
muleskinner
tomtomiS
unless like myself, u took ur car to a tyre place and made the mistake of trusting the fitter. bastard broke one of my centrecaps and it doesnt lock into place, doh!
Bob_S
14" centres wont fit 15" wheels mate. You need the 15" centres. 15" centres off an e34 wont fit you need e30 15" centres which lock when you turn the big nut. IF you have the correct ones, it's a case of turn as far to the left as poss. place on the wheel should locate on 3 pins on the wheel it will then go flush. now get hold of your big nut and turn to the right, it will do about 1/4 turn then click and stop. the cap is on and secure.
Bollocks to this 24v scrap!
SPADGE
If they have an arrow on them mate they are probably plastic E34 push fit ones and won't fit your wheels!
muleskinner
F**K sake this aint happening..........
not again...fucking ebay selling WANKERS.
jmc330i
Sorry mate, doesnt look like an E30 15" centre cap
James
'91 325i Sport
'91 325i Sport
muleskinner
does anyone have an e30 picture of a bbs centre or the correct part number
cheers
mule.
cheers
mule.
kam325itouring
dude they are not e30 ones they are e34 one by the look of it!!! sorry....... the e30 ones have metal plates and plastic lock in nuts, i found this out cos i just got my wheels refurbed and i had to splits the centres all apart!!!!
muleskinner
cheers dude.......
fucks sake.
I am really starting to get miffed off with fucking ebay.
fucks sake.
jmc330i
Can get a couple pics tomorrow for youmuleskinner wrote:does anyone have an e30 picture of a bbs centre or the correct part number
James
'91 325i Sport
'91 325i Sport
kam325itouring
e bay is just a big con mate i ve been stung loads of times, dont trust it as far as i can spit!!!!!! id rather spend a bit extra and get it from euros gsf or even dealers!!!!!
SPADGE
They are deffo E34 type ones mate!
I'll nip down and get you the part number off a proper e30 one right now and post here in a sec.
SPADGE
09-23-117 is on the ones i have here mate
muleskinner
Spadge
have they got 09.24.029 on the inside?
Gortour
Got the 15" wheels on my Tourer. Anyone know a cheap place to get hold of a spanner for that big centrecap nut? I've seen one in a friend's toolkit on her Sport, but haven't got one for mine.
SPADGE
Errrr hang on lolmuleskinner wrote:Spadge
SPADGE
Right here are a couple of pics of a proper BBS E30 cap as you can see it comes in several parts. Note no arrow on the front as unlike the E34 plastic caps these can go on in many ways and not just 1 way round!
The number is just gave you is on the black ring shown in the photo and is 09.23.117 on the back of the badge is the only other part number i can see which is 09.24.030
I just pulled one of the caps of my E34 and it has the same part number you mentioned earlier!
muleskinner
cheers spadge
ive seen and read enough..........
fucks sake...
thanks
tony.
fucks sake...
thanks
tony.
SPADGE
Sorry Tonymuleskinner wrote:cheers spadge
fucks sake...
thanks
tony.
Did you pay much for those caps?
Genuine ones tend to go for upwards of 50 quid a set and singles for about 20 quid upwards.
And to make you happier still - the E34 ones are worth bu**er all.SPADGE wrote:Sorry Tonymuleskinner wrote:cheers spadge
fucks sake...
thanks
tony.![]()
Cut all the back off the E34 ones and glue them in place with silicon rubber.
A1BMW325iSport
hate when people pass the e34 ones off on ebay as e30 ones, i've chucked loads of e34 ones away no-one wants them now
muleskinner
I paid Ԛ£30 for the set.......
i tell ya never again....ebay.
You know I wouldnt dream of ripping someone off.
ill try cutting the back off and seeing if i can get them to even look like they fit right.
cheers
mule
cheers
mule
Cloggy Saint
mrLEE30
mine are threaded and screw on about three turns (16inch splitties)
mrlee
mrlee
cheesebox
Just read this Brian - is this a serious suggestion? Some turdhanger nicked all 4 off my 318is last night. I don't feel inclined to spend £50 on a new set when they'll probably just vanish again. The thought of electrifying them or did cross my mind though.Brianmoooore wrote:And to make you happier still - the E34 ones are worth bu**er all.
Daadji
Why dont you just go to bme dealer they are £28.09 brand new thats what you would pay off ebay anyway
Yes! -I've trimmed one back as an experiment, and it fits in the E30 wheel OK.cheesebox wrote: Just read this Brian - is this a serious suggestion? .
Very slightly smaller diameter than would be ideal, but close enough.
You can drill a small hole through the nut base and into the metal below (no need to drill the wheel itself!) while it is in the locked position, countersink the hole then screw in a small self-tapping screw as an effective anti-theft deterrent.
cheesebox
Brilliant idea. I was reluctant to put the replacement centres back on the car in case they got nicked again.320iSE wrote:You can drill a small hole through the nut base and into the metal below (no need to drill the wheel itself!) while it is in the locked position, countersink the hole then screw in a small self-tapping screw as an effective anti-theft deterrent.
orangecurry
what do you mean by 'nut base'?320iSE wrote:You can drill a small hole through the nut base and into the metal below (no need to drill the wheel itself!) while it is in the locked position, countersink the hole then screw in a small self-tapping screw as an effective anti-theft deterrent.
