Righty-oh!
Stripped the throttle body off with associated pipe work.
I found a worrying amount of water in the pipe between the TB and the AFM?
The little ally elbow came out of the TB without much effort - should it be fixed?
There is emulsion in the oil vapour return pipe that goes from the rocker to the TB, none on the oil filler cap
The black cylinder shaped but that has a 3 pin plug - the internals move but there was some black oil in there - can this be cleaned out and oiled?
What's the deal with the water feed that runs to the TB - cant see a point to it
There is a black connector plug on the loom that connects to the TB that's not connected to owt - surplus to requirements?
The car had stood for a few weeks now, but that amount of water cant be right can it - and could it be the cause of the vapour even when the engine is warm?
Errrrrm thing that's it, is there anything else i need to check over whilst its all apart?
Any help is mucho appreciated
Matt
