which relay is for the fuel pump?
da4x4turbo
Post Sat Sep 30, 2006 3:47 pm
hi lads, i'm in a bit of a pickle.
ok, i have a non-starting 316i. i'm at work and the handbook is at home. so i don't know which relay is for the fuel pump?
and can i interchange it with one of less importance if it turns out to be the relay, just to get me home?
i have eliminated everything i think, except the actual pump or this relay.
Sound!
Anyone who knows of an S50 B32/B30 E30 for sale, please let me know.
Post Sat Sep 30, 2006 4:06 pm
Relay is an orange one (probably) under the wiring cover at the rear of the engine bay. Exactly the same as most of the relays in the fusebox.
Alternatively, pull out the relay and short together pins 30 and 87 of its socket with a bit of wire, but don't forget to remove it later.
da4x4turbo
Post Sat Sep 30, 2006 4:17 pm
ok but as i'm looking at the fuse box which one is it? there's more than one orange one isn't there?
Post Sat Sep 30, 2006 4:21 pm
Brianmoooore wrote:Relay is under the wiring cover at the rear of the engine bay. .
