Steering Woes
bigdek
Post Sat Sep 30, 2006 1:07 pm
Is there any common faults on the steering.
Lately my sport feels quite unsafe at 80mph +
There is no real feel and its like you are not in control.
Seems to wander slightly sometimes as well.
i changed the rubber uj on the steering shaft and have jacked the front up and to see if anything obvious is loose or worn but i see nothing.
Any suggestions guys ?
mattG
Post Sat Sep 30, 2006 1:11 pm
had a similar thing on a tourer changed the drop links quick easy & cheap made a huge differance
fowler
Boost Junkie
Post Sat Sep 30, 2006 1:15 pm
and the rubber coupling on steering cloumn
EX A-Tech Workshop bitch !!!
gone but not forgotten
fowler
Boost Junkie
Post Sat Sep 30, 2006 1:17 pm
is another suspect
lower arm bushes
ball joints tie rod ends all need to be checked
Pas rack ???
mattG
Post Sat Sep 30, 2006 1:19 pm
and who is the bird 8O
Post Sat Sep 30, 2006 1:31 pm
Sure it's not rear steer from worn rear beam bushes?
bigdek
Post Sat Sep 30, 2006 1:38 pm
wot are drop links ?
rear steer ? i changed the trailing arm bushes late last year .
no idea who the bird is but she is luverly !
mattG
Post Sat Sep 30, 2006 2:01 pm
drop links are short bars 4-5" approx that connect to the front wish bones to the anti roll bar on each end, about 10 quid from GFS easy job
gilb
Post Sat Sep 30, 2006 2:21 pm
mine aint feelin to good either got any idea what a knockin noise comeing from the stearing wheel could be when driveing over a bumpy road?
Post Sat Sep 30, 2006 2:41 pm
Brianmoooore wrote:Sure it's not rear steer from worn rear beam bushes?
seems exactly that to me!
Post Sat Sep 30, 2006 2:46 pm
Number one rule when doing any fault finding - check through the last work that was carried out.
Post Sat Sep 30, 2006 2:47 pm
gilb wrote:mine aint feelin to good either got any idea what a knockin noise comeing from the stearing wheel could be when driveing over a bumpy road?
Could be many things, but the last one I did about a month ago was a worn rack.
bigdek
Post Sat Sep 30, 2006 3:24 pm
is that one bush either side ?
How much of a cnut of a job to change them.
i did the trailing arm ones and that wasn't too much of a pain
gilb
Post Sat Sep 30, 2006 6:10 pm
ah cheers dude that will b due to the lack of power stering fluid as i have a leak lol
Post Sat Sep 30, 2006 7:24 pm
Won't be due to lack of power steering fluid. More likely because of it. It washes the grease out of the rack, especially the inner ball joints.
bigdek
Post Sat Oct 07, 2006 3:57 pm
Sadness !
changed the subframe bushes today.
no change to my shit steering problem.
Dont see the big deal in changing the subrame bushes though .
only took 2 hrs :D
Post Sat Oct 07, 2006 4:28 pm
only took 2 hrs :D
Yours can't have been there growing roots for sixteen years!
Check the tracking on this car. Doesn't take much of a knock on a front wheel to put it out enough to make it feel unstable.
