Eko`s M50,On the road now!
silver325i
FIRST LINK IS COOL MATE SOUNDS WELL NICE WELL DONE!!!
eko
- Old timer
Ian,going to tidy up the wiring this afternoon.ian332isport wrote:First, you need to find a 3 pin connector under the dash. You would probably have unplugged this when you removed the original engine loom and ECU. It should have the following wires in it:eko wrote:still need help in getting the tacho working?
Pin 1 - Black
Pin 2 - Green/Red
Pin 3 - White/Yellow
You then need to connect the Black (pin 1) wire to the Black wire that was originally on Pin 20 of the M50 X20 connector. While you are at it, you could also connect the White/Yellow wire (pin 3) to the White/Black wire that was originally on Pin 24 of the M50 X20 connector. This is the fuel rate signal used by the instrument cluster and OBC. The signal is not actually calibrated correctly, but you may as well hook it up.
You need to fit the E30 sender in place of the M50 one.eko wrote: Oh and had it running about 10 minutes earlier and the temp gauge doesnt go very high,wrong sender?
Cheers,
Ian.
Can you just confirm these wires are the last ill need to connect?
Pin 1 - Black - M50 Black
Pin 3 - White/Yellow - M50 White/Black
if these are the last,i can cap off all the other unused wires and seal them up!
Tony
TW166Y
sounds well tony good job dude
Saying goodbye to 4-pot wrongness
eko
- Old timer
Spent the afternoon sorting out the wiring.
All cut down,soldered and heatshrink and hidden in M40 bulkhead cover!
Came out well in the end and looks neat enough.
Got to sort out a leak on one of the PAS unions,p1ssing out,so ill do that tomorrow and wire the electric fan up to a switch but these are both easy fixes.
Then ill stick a seat in and go for a test drive,hopefully tomorrow!
Excellent bit of work - might look you up the next time I'm down your way!
eko
- Old timer
Absolutely Brian,kettles always on for one of the Zone godsBrianmoooore wrote:Excellent bit of work - might look you up the next time I'm down your way!
While your here Brian,you may be able to help?
On the M50 PAS pump there are 3 pipes,I assume the third was something to do with self levelling suspension/wieght adjust steering on the 525 tourer?
Anyway,ive capped it off with -a cut down wheel bolt(made into a stud)screwed into pump,copper washer and nut but it wont seal?
Ive replaced the washer again and it still seeps out.
Any ideas on permanent seal?
Was thinking of putting maybe 2 copper washers on and try that but any suggestions welcome?
ian332isport
If I'm picturing it correctly, it will be leaking past the threads. The copper washer will be sealing the nut against the pump body, but it won't stop high pressure fluid passing between the stud and the nut. Go to your local Pirtek or similar hydraulic merchant. They should have a suitable blanking plug that will seal it up. Just take a sample of the thread with you.eko wrote: ive capped it off with -a cut down wheel bolt(made into a stud)screwed into pump,copper washer and nut but it wont seal?
Ian.
eko
- Old timer
Ill do that tomorrow mate,thanksian332isport wrote:If I'm picturing it correctly, it will be leaking past the threads. The copper washer will be sealing the nut against the pump body, but it won't stop high pressure fluid passing between the stud and the nut. Go to your local Pirtek or similar hydraulic merchant. They should have a suitable blanking plug that will seal it up. Just take a sample of the thread with you.eko wrote: ive capped it off with -a cut down wheel bolt(made into a stud)screwed into pump,copper washer and nut but it wont seal?
Ian.
randomdave325
- Random E30 Nutta
easy tone. looking good!! i land in london at 11 am on sat. should be back in devon land about 1 ish. i'll fire up the hog n fly on down on sat afternoon if you're about. give me a bell if you're not gonna be but other than that i'll see you n ya beast on sat afternoon. i've being lookin for an excuse to drive it again. i'm drivin a suzuki sj atm n it ain't quite doin it for me. still it'll make my thing even better hey! a thrash to newton should blow the cobwebs out nicely i think
p.s i might have an e36 pas pump lurking. i'll ave i look when i get home.
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
'Turning money into noise'
eko
- Old timer
Heres a couple of vids from this morning!
Only really short,i cant go far cause the PAS is p1ssing fluid out.
Couldnt wait for a go any longer.
PS Pulls like f**K
http://smg.photobucket.com/albums/v734/ ... 620003.flv
http://smg.photobucket.com/albums/v734/ ... 620002.flv
http://smg.photobucket.com/albums/v734/ ... 620004.flv
PS Pulls like f**K
....or how to endear yourself to the neighbours!
Well done though. You now know how wrong all those are that say the M50B25 conversion isn't worth it!
eko
- Old timer
Of course its worth it,better than 2.0lt auto anywayBrianmoooore wrote:....or how to endear yourself to the neighbours!
Did get a few dirty looks from the neighbours,especially one in a Pigeon 205 who thought he would be clever and not move out my way,probably cause the bonnet wasnt on-w4nker
d6dph
Fooking hell thats a little loud mate! Wait for the notes from the neighbours
Top work, very impressive.
Ant
- Retired Team Member
Email FTW
eko
- Old timer
Spent the day fitting the leather interior.
Got it all done inc fitting the stereo/tweeters/map light mirror etc.
Didnt get chance to fit amp and sub but that can wait till whenever
Major issue now is getting the steering leak sorted,going to try chemical metal next on the thread,failing that ill have to get another pump of a saloon
Is that with the 4.10 diff?
Doesnt sound half bad at all mate, just wait till you get it to 6k rpm
Are you gonna come to the pod on the 15th? Im gonna be there
eko
- Old timer
Dan,i didnt realise there was another pod meet?DanThe wrote:Is that with the 4.10 diff?
Doesnt sound half bad at all mate, just wait till you get it to 6k rpm![]()
Anyway got a meet not 5 miles away from me on that same date,and theres always a good turnout at these ones -50-60 cars usually!
Not bad for a local meet
Not a meet really, just a run what ya brung day
5 miles to a meet
5 miles to a meet
eko
- Old timer
I know,makes a changeDanThe wrote:
5 miles to a meet
eun
haha you fucking rebel eko
sounds and looks lovely
dark_sounds
"there goes the neighbourhood" lol!!!! id be shot if i done that!!
cracking stuff tony, no doubt a sense of self achievement, make you appreciate your own work more ! lol
how much has it all cost so far??
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
eko
- Old timer
Including buying the car(and selling off some parts from it),buying the 525(selling bits from that)then buying all the parts to fit it,the whole thing has cost about Ԛ£200dark_sounds wrote:"there goes the neighbourhood" lol!!!! id be shot if i done that!!
Still got a few bits to sort out though so that may go up a bit more!
dark_sounds
lol!!!! cracking stuff! thats what im talking about!
realistically, if you were to do the engine conversion again, now that you know what you are doing, how long would it take you reckon?
eko
- Old timer
If all the parts were their ready i reckon 3-4 days?
Maybe a coiple to sort out the finishing touches and tidy things up!
dark_sounds
not too bad eh? well must say it is looking very good, whats the plans for it now??
eko
- Old timer
Replace rear skirt with correct Mtec1,and just generally improve it overall!dark_sounds wrote:not too bad eh? well must say it is looking very good, whats the plans for it now??
Problem is i get bored of the same car very quickly,so what the future holds,i dont know!
camcc
looks and sounds amazing! I'm really quite jealous.
I must have a spin in it at a meet in the near future
eko
- Old timer
Chris,it would be my pleasure!camcc wrote:looks and sounds amazing! I'm really quite jealous.
eko
- Old timer
Well had my first proper go in it today!
Only went to Sainsburys to put petrol in it,but what can i say-goes like stink
Was saying to myself,dont boot it,its the first go in and and dont want anything falling off but...got to the junction at the top of my estate,gave it some beans in 1st/2nd,went to go for 3rd and - ripped the fooking centre bearing on the prop
My own fault really cause i should have fitted a new one before it was fitted!
Picking up a E36 325i prop tomorrow and going to fit a new centre to it before fitting.
Apart from that its sweet.
Still got loads to do yet,but basically it should be on the road this weekend?
Thanks again to all that have helped out with advice,you know who you are
Ill get a video up soon!
Oh yeah forgot to mention the noise
Sounds like a V8 on full chat-booted away from that junction,the look on everyones faces was great
eun
[/quote]
haha awesome mate bet it sounds fookin crazy pure power
eko
- Old timer
Eun when i say its loud,im mean its crazy loud!eun wrote: haha awesome mate bet it sounds fookin crazy pure power
Nearest thing i can compare it too from memory is my mates old Skyline fitted with 5 inch pipe
Cant leave it like this but seems a shame to cut a piece of the stainless out to add centre box
Think ill put up a post,see if anyone knows if i can pack out the backbox with silencer wadding?
Pal318is
Have been checking this out in the background really and tbh, all credit to you Tony, amazing job.
Well Done.
Pal
Well Done.
Pal
Pal
[img]http://
[img]http://
eko
- Old timer
Thanks for the compliment Pal
Should be on the road as from tomorrow,just got to sort the prop bearing out.New one in the post today so hopefully turn up tomorrow!
Running on the BBS`s for now,tyres on my Hartges are shagged,cant afford to replace them till next week!
gcorky
- Boost Junkie
eko
- Old timer
Might look into a 5 stud conversion nextgcorky wrote:hehe eko ,great car m8....i too get bored very quick!
