can anyone help with the above and let me know.
cheers
mule
what offset is ok for 17 inch wheels?
buster
25 i believe
dazzaboy
i have team dynamics Osaka wheels with a 35 or 38 offset, but luckily they make 10mm spacers which fit straight onto the hub with out the need for spigots
ps. i needed longer bolts
m-dtech
- Unapproved Trader caution
i have converted to studs on my car, i have 17" wheels with an ET of 40 ! ! ! !
to combat the high et i have 16mm spacers that get the wheel sitting proper !
Gouki
bout 20-25mm is the right offset. You can fit them on without but you'd probably end up having the wheels tucked too far back.
Steviec
My latest wheels have an et35 and are 9" wide. The rears JUST fit on the inside but the fronts dont clear the calipers so I need spacers for them.
<a><IMG></a>
orangecurry
that's consistent then - they all end up being around 24 (after correction with spacers); that'll be for 7 inch or 7.5 inch width wheels
your 9 inch wheels StevieC- what the offset should be needs more maths than my brain can cope with
Jos
mine are 7.5x17 ET35 and sit ok
'94 e36 tree climber
e30_Turbo
- Boost Junkie
Ziggy
Hartge used et20 for their 7.5J wheels too (16" but that ain't really the point here!)... Mine'd rub on the arches (on 205s) if the offset was any lower I think!
orangecurry
not on my 16" 7.5J Hartges they didn't
ET25 is stamped for all to see
Ziggy
Ok, they did on the split rim versions though, so I guess they figured it was ok!
orangecurry
and we are only talking about 5mm here!
it's lowering AND offset AND tyre width that CAN cause a problem
