Cheers Spadge...
E34 LSD - Same as E30???
SPADGE
I know its a long shot and i'm 99.9% sure they arn't the same but can someone confirm an E34 diff won't fit an E30? Just discovered my 535 donor car for my 335 conversion has a slipper
If it won't fit can anyone tell me what it may be worth in good order?
Cheers Spadge...
Cheers Spadge...
Avner
I think it is a differemt case, but if you have a big cased diff maybe you could swap the LSD center.
steerfromtherear
I asked this same question only a couple of weeks ago and apparently not.
I would have thought value would be similar to an e30 slipper? Ԛ£200 - Ԛ£300. Plenty of e34 lads out there after one I bet. Not so many e34 sports to half inch em from as e30 sports is there.
SPADGE
Cheers guys i'll have a go at selling it or if it doesn't go i'll see if i can get it put into an e30 case.
Does anyone know what ratio its likely to be?
Cheers Spadge...
Cheers Spadge...
Andyboy
- Alpina Colada
E34 LSD's are worth f*ck all - Ԛ£150 if it's a 3.91 ratio M5 unit. E34 parts are just worthless now, their day has gone!
I'm pretty sure the 535i LSD unit fits into a big casing E30 diff.
pf525sport
offer it on the bmw5 website.
i dont agree with andyboy that their day has gone but you dont get the same enthusaism for modding e34's as you do e30's ,(putting the cat among the pigeons now) even though the e34 is a superior car.
Paul
Paul
1990 3.6 m5 extended champagne leather 058 rondells etc etc
SPADGE
Hi matepf525sport wrote:offer it on the bmw5 website.
Paul
Just went on the 5 site and they want a tenner for me to join or for me to make 50 posts before i can advertise
I've stuck it on ebay now so we'll see what it fetches
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=014
pf525sport
if you want I will put it on there for you if you give me some info-IE what car it came of,condition etc etc
paul
paul
SPADGE
Thanks guys
It sold now through ebay
Andyboy
- Alpina Colada
But why bother when there are so many ratios available on the E30 and E28 diffs from 2.97 through to 4.41? Seems like a load of work and aggro for nothing. All that beam welding, different driveshaft flanges, different rear mounting, different prop flange. When a big casing E30 Type 188 diff is all but unbreakable it seems like a waste of time - but I'm sure there's a reason!ed325i wrote:It can be made to fit.
Andy335Touring
I think it's from a Sweedish E30 with an S38 and a BIG turbo(800-900bhp) ?Andyboy wrote:But why bother when there are so many ratios available on the E30 and E28 diffs from 2.97 through to 4.41? Seems like a load of work and aggro for nothing. All that beam welding, different driveshaft flanges, different rear mounting, different prop flange. When a big casing E30 Type 188 diff is all but unbreakable it seems like a waste of time - but I'm sure there's a reason!ed325i wrote:It can be made to fit.
jmc330i
Yup, thats the one.Andy335Touring wrote:I think it's from a Sweedish E30 with an S38 and a BIG turbo(800-900bhp) ?Andyboy wrote:But why bother when there are so many ratios available on the E30 and E28 diffs from 2.97 through to 4.41? Seems like a load of work and aggro for nothing. All that beam welding, different driveshaft flanges, different rear mounting, different prop flange. When a big casing E30 Type 188 diff is all but unbreakable it seems like a waste of time - but I'm sure there's a reason!ed325i wrote:It can be made to fit.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Andyboy
- Alpina Colada
Aaaaaaaaahhhh..............
But the E28 535i diff is stronger and bolts straight into the E30 axle beam. The E34 diff uses E30 bits inside.
jmc330i
Its the E34 M5 diff fitted to that 900bhp M3, which Im guessing is a little stronger than a 525i diff.
James
'91 325i Sport
'91 325i Sport
