suspension. what else should i replace while im at it?
FBF
Post Tue Sep 12, 2006 3:36 pm
putting in new springs soon. is there anything else i should change while its all apart?
im so sexy justin brought me back 5 times
320Touring
Post Tue Sep 12, 2006 3:38 pm
FBF wrote:putting in new springs soon. is there anything else i should change while its all apart?
Id do the rear topmounts-fairly common failure, and I hear that someone has written a guide for it... :wink:
orangecurry
Post Tue Sep 12, 2006 3:59 pm
FBF
Post Tue Sep 12, 2006 4:51 pm
great i knew it would be worth asking some have come on ebay this morning too.. i will have a bid.
FBF
Post Tue Sep 12, 2006 4:56 pm
bugger 'not for touring or cabs' can anyone suggest a cheap stockist? dont want to pay 75 quid if i can help it
Ziggy
Post Tue Sep 12, 2006 5:06 pm
Stockist for what? Springs?
& blimey - twas the best part of a year ago wasn't it! 8O Need to check my GSF "uprated" topmounts at the weekend - I've a feeling they're going again. Will definately go with the e46 ones this time (if I can get hold of some!).
Rear topmounts aren't really essential to do at the same time as the rest of it btw - you can do em on their own. Probably will need doing though, so it's still good advice! :)
FBF
Post Tue Sep 12, 2006 7:05 pm
stockists for the rear top mounts
Ziggy
Post Tue Sep 12, 2006 7:42 pm
Erm... Ԛ£7 ish from ECP / GSF or slightly more for E46 cab ones (better design) from the dealer! :D Can't see how you could ever spend Ԛ£75 tbh...
pnd
Post Tue Sep 12, 2006 7:46 pm
Some decent ARB's eg the H+R ones from the zone shop will transform the car. The best mod in my experience.
Dan318-is
Post Tue Sep 12, 2006 7:50 pm
If you cant afford all new roll bars just change the links themselves, about 9 quid a pop but will actually make sure your roll bars are doing what they are suppose to do.
Bushes are probably the most important things to check for; control arm diff and subframe ones and roll bar ones especailly
Post Tue Sep 12, 2006 8:52 pm
Im putting these on mine tomorow winkeye
I had the arms and bush carriers powder coated (because im too lazy to paint them) :) and I pressed the new ball joints and M3 eccentric bushes in today
Hopefully it will stiffen things up plenty
