Any advice welcome!
Retrofit rear headrests to a touring
wightE30
Anyone know if a set of rear heads (with brackets) from a 2 or 4 door will fit a touring? Bit concerned about the 60/40 rear fold, and if there is sufficient space (width) in the 40% to take the bracket. Must be possible since tourings can have rear heads - but is it a different mounting bracket?
Any advice welcome!
Any advice welcome!
E30Mark
From what i know of tourings the headrests & fixing brackets are both the same as the front seats.
PM for details
PM for details
Geeman
I thought that all Tourings already had the brackets in the seat backs, they just need a hole making in the top to fit the headrests themselves through...
Could be wrong though.
gareth
yeah, teh touring has the brackets already in the rear seats. you'll need the matchin headrests from some front seats and the clips etc too.
i've just done it... seems i'm not alone: http://www.e30zone.co.uk/modules.php?na ... 5377#45377
Themetal part of the brackets is already on the touring rear seats. You still need the plastis liner, spring clips and grommets from a scrap front seat.
andyp
- True Old Skooler
yep just done this tonight, the round metal bracket is made in the frame of the seat of the touring, you need the plastic bits from the front seats of a car which then fit into the metal frame, i will along with sir B be doing an article on this soon with pics
wightE30
Thanks everyone for the replies - a simple point, but incase anyone else is watching this thread, the front and rear heads are the same, they can be interchanged.
Front what I've read above it looks like the tourings have it easy, a set of fronts plus the tubes/spring clips/inner and outer grommets and you are sorted.
Brackets from a stealer are only about Ԛ£18 for the non-load luggers.
FAO Andyp - I'll PM you some more pictures that might help you article
