Sooty
Post
Fri Sep 01, 2006 9:37 pm
Anyone know how difficult it is to convert a manual sunroof to electric operation?
Thinking of taking the elect one out of my touring & putting it in the 320.
Iain S
Post
Sun Sep 03, 2006 4:35 pm
Fairly easy. Remove the whole motor assembly including the guide tubes, leaving the flexible cables behind.
Use the handle or motor to wind them in and out, or just remove the handle mech and motor.
Wiring loom is a single wire which runs up the LH screen pillar from the accessories socket at the back of the glovebox.
Simon
Post
Sun Sep 03, 2006 6:59 pm
Iain, there have been some good posts on this, a quick search will find them, this one has quite a bit of info..
http://www.e30zone.co.uk/modules.php?na ... conversion
I've done it on my M3, and had a total nightmare at it, found the motor mounting holes didn't quite line up with the mouting plate from the manual roof, but got there in the end!
Post
Sun Sep 03, 2006 7:23 pm
Simon wrote:, found the motor mounting holes didn't quite line up with the mouting plate from the manual roof, !
Thats why you should change the whole mech and not just half of it!
Simon
Post
Sun Sep 03, 2006 7:30 pm
Brianmoooore wrote:Simon wrote:, found the motor mounting holes didn't quite line up with the mouting plate from the manual roof, !
Yeah, would have been easier, but at the time I did my conversion, the advice was to fit the motor to the manual mounting plate!
Sooty
Post
Sun Sep 03, 2006 7:32 pm
Cheers for that Simon.
Transferred all the info from that link on to a Word document & I'll start trawling through the rest when the Zone comes back on line in a couple of days.
Got to concentrate on the M50 for now or I'll never get it finished in time for Santa Pod.
Shame there are none of the regular volunteers close by to give me a hand
Post
Sun Sep 03, 2006 8:28 pm
The first reply in that thread is by me. I'm older and wiser now, and wouldn't do it like I said in that thread any more.
Since then I've done a couple more, and definitely recommend changing the whole plate complete with guide tubes.
Sooty
Post
Sun Sep 03, 2006 8:33 pm
Noted Brian. Many thanks.
Pal318is
Post
Sun Sep 03, 2006 8:36 pm
Mine is still fooked, need to pull my finger out of my arse and get this sorted, it's just proving to be a pain in the arse as my roof seems like it's jammed
Pal
Pal
[img]http://
Sooty
Post
Sun Sep 03, 2006 8:44 pm
Got the same problem Pal, hence the reason to change.
I'll get a better idea of what goes where when I start to frag the Touring, but it probably won't happen until after Santa Pod.
Iain S
Pal318is
Post
Tue Sep 05, 2006 6:05 pm
Sooty wrote:Got the same problem Pal, hence the reason to change.
Iain S
Let me know for def if when you do bud. just so i can pick your brain and possibly get some sort of an idea of how i'm going to repair it..
Pal
Pal
[img]http://
Sooty
