ABS Anoying Bloody System.HELP.....
- fowler
- Boost Junkie
- Contact:
what you need it sounds like and ABS ecu problem ??? you can buy all these bits off the zone speak to dips346 or jonb i am sure they will have the bits you want
EX A-Tech Workshop bitch !!!
gone but not forgotten
These are the exact same symptoms of my problem that I had 2 years ago. The problem was a faulty sensor giving the wrong readings. You can test the resistance of the sensors with a voltmeter, they should all be about the same, any variations and the sensor will need replacing. You could disconnect on abs sensor and i think this will deactivate the system.
I know what you mean about it being dangerous it just feels like the car wont stop, well it doesn't it just makes a crunching noise and doesn't do a lot.
So i think have a look at the sensors first then the relays and then the ECU.
2 cents
Jon
2 cents
Jon
