Ziggy,
you see the water pipes marked in red, when you change over the TB you can join these together with a little bit of pipe inserted in to them, they dont do anything apart from circulate in the TB from the thermiiietwat and the block and all there doing is heating up the TB for no reason what so ever,
(and a bit of inside info on the BBTB your getting) that side is allready blocked off nice and neatly, so you'll have to join the pipes anywhooo
the vacume pipe on the right, marked blue, im sure you can just change from going from two pipes down to one, with no diffrence to the car at all,
and the chip thing, a just dunno, just send the BBTB to me and i'll test it on a chip
