just found out why my sport ticks like a bomb
some pilluck has threaded the end stud and it barely bites into the head at all so my Q
is there anyway to get this stud to hold in tight??
even if its only gonna last a month or 2 it will do as i have a spare head just dnt have a couple ton to put out right now to swap it all
any solutions welcome
araldite mate??
cheers
Daz
threaded exhaust stud
dazleeds
- old skool raver
www.oldskoolfantasy.co.uk
mikey-t
how many people are posting about head studs at the moment! are we all killing them
dazleeds
- old skool raver
i wouldnt mind so much if i had killed itmikey-t wrote:how many people are posting about head studs at the moment! are we all killing them
mikey-t
exactly the same here mate! except on mine someone has tried drilling round the stud too! you know the big bit of metal that is a cylinder head!
incompetent muppets
incompetent muppets
JimmyC
remove the stud, re tap and replace the stud
depending on the damage to the head you may need a larger stud, but reading your post it sounds like the studs shagged not the head so no biggy
dazleeds
- old skool raver
at a guess id say the holes chewed mateJimmyC wrote:remove the stud, re tap and replace the stud
stud comes out with the metal in the thread if ya get what i mean
studs in pretty good condition
dnt think it can be retapped with head on as its the top stud near bulkhead
johnna
- E30Zone Irregular
wind on two nuts and lock these against each other, then the inner one of the two can be turned and will remove the stud with it.
It all the threads are off- use a set of (probably smaller than usual) stillsons (plumbing wrench) to grip and turn the stud.
Failing that, shear it at the head face, centre punch it then drill into it with a cobalt drill bit. Keep increasing the size of the cobalt drill bits until the appropriate size of tap can be applied.
Ever had to drill out a cylinder head-bolt? Now that IS hard!
mikey-t
cylinder head bolt!!! nightmare!!!! i know!!!!
only possible way is a pillar drill and lots of swearwords! cant risk hitting a waterjacket
dazleeds
- old skool raver
johnna
the studs out mate fell out as soon as i touched it hasnt snapped
the prob is the hole the bugger goes in has no thread left hardly so guessing it has to be helicoiled but im sure ya cant do the end (bulkhead) with the head on
liquid metal? wonder if that would hold it in for now??
Templ8e30
Daz, I've got some timeserts at work (like helicoils but stronger) could give them a go before you whiz the head off.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
dazleeds
- old skool raver
if ya reckon its worth a try why not mateTempl8e30 wrote:Daz, I've got some timeserts at work (like helicoils but stronger) could give them a go before you whiz the head off.
Cheers,
Iain T
sounds moocho cheaper for the time being
but still wanna change hd gasket soonish prevention better than cure etc
you coming to fb sunday?
can sort sometime out to look properly
