just a couple of Qs
1, are the pipes same on a 320/325i rack??
2,do i have the right bits
pas rack/pump/res bottle/belt/pump mount/belt/pulley wheel
anything else ??other than pas fluid
and do i bleed it with wheels on the ground or off??
also should engine be running when i bleed her??
cheers all
manual to pas help
dazleeds
- old skool raver
www.oldskoolfantasy.co.uk
Chris-W
dazleeds
- old skool raver
Damn it seems i missed loads of people yesterdayChris-W wrote:All sounds good Daz - yes, wheels off ground ideally & engine on.
Saw your Sport yesterday but couldn't find you?
just trying to get some temp ins cover on the touring so i can get some stuff sorted on the sport
great stuff thort i had the bits needed cant live with a manual rack lol
Martinaston
It can depend on which rack you have, some are all aluminium and the older ones can be steel.
If you look at the back of the pump some have the connections 90 degrees apart and some have them about 50 degrees apart (can't remember which) and they have different mounting brackets.
They both run at the same pressure and can be swapped but it gets a bit tight with the return pipe.
There is NO nucleus.
stuartgallafant
dazleeds
- old skool raver
rack and pump came off the same carMartinaston wrote:It can depend on which rack you have, some are all aluminium and the older ones can be steel.
but ill be using the pipes from a hreg 320i se
just realised ill have to change the linkage from sterring column to rack to wont i??
sure man has diff linkage? am i right if yes thats coming off the h reg 320i too
stuartgallafant
