Junk-Yard Turbo hunt
mattG
Post Thu Aug 10, 2006 4:10 pm
What turbos from what cars are worth getting to build hybrids?
e30_Turbo
Boost Junkie
Post Thu Aug 10, 2006 4:17 pm
mattG wrote:What turbos from what cars are worth getting to build hybrids?
Anything off a 2 ltr and above really, plenty of rice have fair sized blowers. Cossie T3's are a resonable size too.
Or you could always try a HOLSET :D
mattG
Post Thu Aug 10, 2006 4:50 pm
what is the t3 t4 hybrid
gcorky
Boost Junkie
Post Thu Aug 10, 2006 4:53 pm
usually t3 turbine with t4 compressor. :D
525 sport
mattG
Post Thu Aug 10, 2006 5:10 pm
what cars have the t4
jamesc
Post Thu Aug 10, 2006 5:40 pm
Is a cosworth turbo big enough for a 2.5?
Dan318-is
Post Thu Aug 10, 2006 5:42 pm
what one of you boys wants to do is this. get a tiny turbo of a van, for instance Oguz3301 (Oz) astra van, and use that to spool up a holset. bye bye lag!
OT Mattg you have PM
Ant
Retired Team Member
Retired Team Member
Post Thu Aug 10, 2006 5:44 pm
Cossie turbo is fine up to around 320 bhp on the 325, Its what I have although mines slightly modded with a bigger A/R turbine housing and a back cut on the turbine blades
zero lag, lots of midrange, perfect imho, unless you want a 4K onwards monster, ideal for the 1st FI experience :lol:
mattG
Post Thu Aug 10, 2006 5:50 pm
could always fit your holset if you' to scared to.lol winkeye
Ant
Retired Team Member
Retired Team Member
Post Thu Aug 10, 2006 6:00 pm
Soon , but not quite yet Matt :wink:
jamesc
Post Thu Aug 10, 2006 6:01 pm
Ant wrote:Cossie turbo is fine up to around 320 bhp on the 325, Its what I have although mines slightly modded with a bigger A/R turbine housing and a back cut on the turbine blades
Cool that sounds good for me... what kind of flange do they have - would one fit onto a TD manifold?
James
Ant
Retired Team Member
Retired Team Member
Post Thu Aug 10, 2006 6:24 pm
T3 inlet, no use on the TD manifold M8
jamesc
Post Fri Aug 11, 2006 12:07 am
I thought the TD manifold was T3 (sure I read that on e30tech??)
Kos
Post Fri Aug 11, 2006 1:46 am
i can put you in contact with my turbo guy, he's 5 minuted down the road and he can build you a custom one for sensible money
i've used him for years, for my RTS and GGT he's made the one on a 325i turbo touring dips had, the monster on his cossie
and he'll be making one for my M3
www.pukardesigns.com
IG Pukar.Designs
e30_Turbo
Boost Junkie
Post Fri Aug 11, 2006 8:45 am
jamesc wrote:I thought the TD manifold was T3 (sure I read that on e30tech??)
I think it's more to do with the space available when using the TD manifold, Jon_bmw had a good time playing with his so I'm sure he can more specific in the why's.
HTH, Mark.
Jon_Bmw
Dangerous when thinking
Post Fri Aug 11, 2006 11:53 am
Well the americans use the 324td manifold, which has exactly the same ports onto the cylinder head, but has the t3 flange instead of the 3 bolt one seen on UK 325td/525td manifolds. If you can your hands on a 2.4 manifold then that one is probably easier to fit a larger turbo on.
Problems: spark plug access is zero
A large turbo with a big compressor housing "may" foul the rocker cover (you can lift the turbo up with a flange piece to help this though.
Trying to source one for reasonable money is nigh on impossible. You need to find one in the netherlands or germany that isn't on ebay because i'm sure the americans scower ebay.de for the exact same thing.
Having seen Ant's BBR(?) manifold in real life, it shows what a nice bit of kit it is. It makes everything tidier, spark plug access is better than factory i think and it just bolts on :cool:
Hth
Jon
jamesc
Post Fri Aug 11, 2006 8:10 pm
My Td manifold has a 4 bolt flange?
James
JAMZ
Post Fri Aug 11, 2006 10:01 pm
Does that Mani look thin or is it just me..looks alot thinner than the one i got anyhow
Jon_Bmw
Post Sat Aug 12, 2006 12:03 am
James that is a t3 one, must have come off a 324td, you are a lucky man. You can enlarge that EGR flange too and make it suitable for an external wastegate.
