Homemade M20 Log mani
WillG
Ok after a attempt at a tube mani with pipe way to thick, it got 1/2 done was so heavy and twisty i gave up becuase I couldnt be bothered with effort to get more suitable pipe and start again (doin this in back garden btw) and thought i just order PPF one, but PPF one will take a long time (months) to come, if they make me one atall , and i thought well BMWSOB is making near 400 hp and 11 sec 1/4 with a log so I decide ill knock one up and try it and if im not happy with it and I think its holding me back ill beg PPF to make me one.
http://nafiannadragun.co.uk/will/DSCF0222.JPG
http://nafiannadragun.co.uk/will/DSCF0223.JPG
http://nafiannadragun.co.uk/will/DSCF0224.JPG
Will get both surfaces skimed as its warped abit and caught with grinder a small bit, found place with furnace aswell to stress relive it first so I dont get it skimmed put it on and warps again when it heats up.
Only worry is wastegate is very close but its even closer on TCD mani and i found out the diaphram/spring in tial wastegte take 900F so it should be ok. divided flnage is ported to edge on inside rather then porting turbine housing. Gona see how this works, wont spool so well as proper manifold but I dont really care about that.
Jos
ok mega OT here lol, Na Fianna Dragun? As in the Hib/Pryd DAoC guild?! lol.. it is too. I used to play there
Awsome work on the mani too!
'94 e36 tree climber
Turbo-Brown
- Boost Junkie
Hey, that looks pretty tidy!
Can't see you'll have any problems with spooling with that
Head flanges look familiar too! Seems they're turning up all over the world! A guy in Australia's using them now and I've sent loads of people in the states the drawings too!
WillG
no idea, asked a friend for some space and its what I got, he sais it is tho.
yeah pleased with mani will be nice to see what its like wont be bothered if it sucks it didnt cost much and ill sell it, but im just waiting to see what its like and get everything else setup and if i dont like it then ill change either turbo to small or manifold to 6-1. its lighter then the stock cast log aswell which is nice, the 6-1 i tried weight a tonne before i even finished it.
WillG
yeah cheers for the drawing mateTurbo-Brown wrote:Hey, that looks pretty tidy!![]()
Ant
- Retired Team Member
Very nice work Will !
logs kick arse, they solve more issues than they create IMHO
Good progrees M8
Good progrees M8
Email FTW
Toby_Unna
- Boost Junkie
good effort, that looks cool Will.
mine looks utterly shite and the internals aren't exactly smooth, but it spins up at 2k in higher gears and always makes full boost by 3k, which is fine by me
back garden, lol. i made mine on the gravel driveway
e30_Turbo
- Boost Junkie
mattG
Looks good, is the disadvantage of logs to do with unequal distance from ports to the turbo?
e30_Turbo
- Boost Junkie
It's not too big of an issue to worry about it at our level of modding, anything less than 300bhp or so should be fine on a log.mattG wrote:Looks good, is the disadvantage of logs to do with unequal distance from ports to the turbo?
All these fancy equal length manifolds only really come into their own over a certain amount of flow. And having driven Ants car a few times I certainly couldn't feel a difference to my 7 branch....
Well apart from the space issue.....
Mark.
dan_emaps
Looks smart dude! very good work for a back garden job!!
mattG
bumb question whats the 7th branch?certainly couldn't feel a difference to my 7 branch....
e30_Turbo
- Boost Junkie
mattG
still leaning
e30_Turbo
- Boost Junkie
WillG
its 2 things really, more equal runners are better for same reason people fit 6 branch manifold to NA engines but its also about the pulses, the 6-1 manifolds perserve the pulses better and help spool the turbo abit earlier which is why you have divided entry on holset turbos aswell. Also a 6-1 will flow alot better then if you used an adapter on stock manifold as pipes on stock manifold are quite resiticted, this log will be alot better then using adapter and should flow as much a a 6-1 becuase the way ive used bigger pipes as it gets nearer the collector there is as much or more crosssection area of pipe as you would have in a 6-1mattG wrote:Looks good, is the disadvantage of logs to do with unequal distance from ports to the turbo?
mattG
WillG will your turbo have an internal waste gate for your manifold,
cheers for the pick fozzzy
WillG
no if you look at manifold there is a vband flange on there right in collector for 44mm tial wastegate, my turbo is a HX40 19cm3 64/74 turbine and 55mm compressor inducer, its probly gona be to big so ill sell it and buy a HX35 but that will be after ive tried it properly with electronic boost control to make sure wastegate stays shut, its a 15 psi spring so ill leave bottom open and feed top of wastgate with boost pressure to keep it shut till about 20 psi only way id change it is if I get lag between 3-4-5 redline gear change
WillG
i think turbine is alot like marks but the compressor is abit bigger
mattG
is the v-flange the round hole below the turbo mount on pic 3
miniblob
I don't know much about them, but that looks pretty damn good for something you made in the garden!!
327 Touring with bass!!!
e30_Turbo
- Boost Junkie
I measured mine to be :WillG wrote:i think turbine is alot like marks but the compressor is abit bigger
Cold side: 50mm & 82mm
Hot side: 67mm & 63mm
Exhaust housing is 18cm3
And I know someone else on here has wheels bigger than mine
For reference 18cm3 housing gives full boost on my setup @ 4k but you do see boost from 3k
HTH, Mark.
Ant
who is that then Mark ?
Email FTW
e30_Turbo
- Boost Junkie
WillG
fozzy mine sound exactly like your accept that the turbine is T4 flange and i must of measured the wheel wrong, i got 64mm on turbine exducer and 74mm on turbine inducer. did i measure in wrong place?
e30_Turbo
- Boost Junkie
I'm on a T3 flangeWillG wrote:fozzy mine sound exactly like your accept that the turbine is T4 flange and i must of measured the wheel wrong, i got 64mm on turbine exducer and 74mm on turbine inducer. did i measure in wrong place?
I measured the compressor wheel at the inlet, so across the most forward part of the wheel and then the back of the wheel, 50 at the inlet which increases to 82mm at the back.
The hot end is reversed so bigger size is the inner or back of the wheel and the front or last part of the blades for the other.
Then you can work out the trim:
trim (50/80)^2 = 0.39 = 39 trim
HTH, Mark.
WillG
41 on compressor and 74 on turbine then, that sound about right?, was you turbine sizes a miss type in previous post? my turbine exducer is same as you but inducer is 84 on mine and 77 on yours?
e30_Turbo
- Boost Junkie
WillG
on turbine its the other way round tho, you swap then round, im talking about turbine side
gcorky
- Boost Junkie
bit ot-soz ,fozzy did you get a 3 inch pipe between block and column ok?your not using any boost control are you....no control valves etc...
got a v-band flange made gratis today....got hold of a gaffa from a machine shop and asked for a price -he turned up 2 hours later and said ,i can have.....guess whos gonna do my wastegate flange for screamer.....????
wonder why you dont get them?with w/g ?
got my downpie bits in 3 inch stainless from the machine your turbo came from-not much of that buggger left now..lol.ill speak to Ant shortly r.e the pipes youve got for system...
e30_Turbo
- Boost Junkie
Ant
Pah , too small
mines:
HX35W
17cm/3 housing on hot
comp is 57/82
turbine is 77/61
mines:
HX35W
comp is 57/82
turbine is 77/61
Email FTW
e30_Turbo
- Boost Junkie
Ant
christ I hope not
will measure again when she's clocked
Email FTW
mattG
what sort of measurements would a t3 and a t3/t4 be ?
