how much wider are M3 arches?
gareth
Post Wed Aug 09, 2006 7:47 pm
does anyone know how much extra width the M3 arches will handle?
i have naughty plans brewing with a set of ET13 8.5J16 BBS rims i have.... winkeye once spaced to clear my calipers, they sit about 1.5" - 2" clear of the front arch (propped up on a jack for a best guess). is this likely to fit under M3 arches if i build a M touring?
miniblob
Post Wed Aug 09, 2006 9:34 pm
Build it anyway!!!!!! Could look really sweet!!!! :cool:
327 Touring with bass!!!
gareth
Post Wed Aug 09, 2006 10:46 pm
just seen this... i was wondering if it was possible and it seems it is! m3 arches and it's finished!
Jos
Post Wed Aug 09, 2006 11:26 pm
http://www.terrysaytherauto.com/yet_ano ... ct_car.htm
Looks the NUTS, but you would need to sleep with a bodywork specialist to get those rears done!!
'94 e36 tree climber
gareth
Post Thu Aug 10, 2006 12:16 am
love it! perfect in 2 door though.........
Kos
Post Thu Aug 10, 2006 3:25 am
that touring has a BBS kit , not M3 arches!!!
doughboy
Post Thu Aug 10, 2006 6:40 am
Sorry, but ihmo that bbs kit looks nasty.
M3 arches would look pretty sweet on a mint touring.
Jos
Post Thu Aug 10, 2006 2:44 pm
gareth wrote:love it! perfect in 2 door though.........
Yeah but only 4 ever made lol...and that white bbs kitted one is one of them.
Aico
Post Thu Aug 10, 2006 11:15 pm
I have that set-up on my E30, 17x8 ET05. A bit different, but it sticks out the same. At the rear it fits with rolled fenders. At the front it clears the fenders if you don't lower it more than 4cm. You should get stiff enough suspension or it might still rub. The rim almost hits the fender in the corners with stock suspension.
I'm also looking in getting the M3 panels fitted, but I don't think they are that much wider. Maybe 10-15mm. The rims don't clear the suspension very well since I have Intrax coil-overs F&R so I'm going for 15-25mm spacers. Now I have to figure out what I need to do to the body. I'm picking up GRP M3 panels this sunday so then I'll see howmuch wider they really are.
Kos
Post Fri Aug 11, 2006 2:07 am
m3 rear arches will clear 9" rims easily with the corrct offset
i run 10x17's et15 and they only need a slight roll afer suspensin was lowered
popeye
Post Fri Aug 11, 2006 5:33 pm
Zender made a 2 door conversion for the touring in the eighties, didn't really take off at the time though.
popeye
Growing old is mandatory, growing up isnt!!!
ant2
Post Sat Aug 12, 2006 12:22 am
i am running a 9.5*16 et 13 on the back and 9 et12 on the front and it just goes with plenty of front camber, i have adjustable trailing arms on the back so can pull the rear wheels in
pic here http://www.am-ant.net/e30-335/Image119.jpg
gareth
Post Tue Aug 15, 2006 9:22 pm
Kos wrote:that touring has a BBS kit , not M3 arches!!!
i know. and i don't like the BBS kit, that why i said that it would be finished if it had M3 arches... 8O
cheers for the figures lads... time to get the tape measure out.....
Aico, id be very interested in the increase in usable width as and when you offer things up :D
m3ben05
Post Tue Aug 15, 2006 9:28 pm
M3 arches were only designed the way they are in order for the race cars to be able to run 10" rims - obviously road cars have inner arches but 9" rims are no problem with minor mods.
keego1ie
Post Thu Aug 31, 2006 9:51 am
Have you considered the body kit off a e30 325ix as this has wider arches as part of the kit?
http://www.toodarkpark.org/digicam/2002 ... ges/4.html or
silver car is an ix
gareth
Post Sat Sep 02, 2006 9:17 pm
i'm not a fan of the ix kit as imo it looks very cheap and stuck on. i assume it won't actually give more wheel clearance to the original arch underneath either.
