Cheers guys[/img]
Depends where the rust is, if it's around the glass frame, then it will be near the dash, and will require dash removal.tez wrote:Is it safe to weld in new sections with dashboard in place or is it best to remove , i can see mine going up in smoke knowing my luck?
