Rust on Scuttle panel
eldarvanyar
Post Mon Aug 07, 2006 8:09 pm
I have got some rust on both the offside and nearside scuttle pannel corners, and hnow have a hole the size of a 2p on the nearside. What's the options, can you still buy the scuttle pannel section, and replace the whole lot? What's a good way to deal with it.
Cheers guys[/img]
Jos
Post Mon Aug 07, 2006 8:12 pm
:ttiwwp:
:) Lets see how bad it is 1st before making a call on it
'94 e36 tree climber
Post Mon Aug 07, 2006 8:15 pm
not sure if this means it is still available or not?
http://www.realoem.com/bmw/showparts.do ... g=41&fg=30
stevieg
Post Mon Aug 07, 2006 8:32 pm
The only proper way to deal with scuttle corner rot is to remove the wings,bare metal the affected area,cutting the rot back to good metal and letting in some new metal,it's not too hard to form,the do the filler and primer and either mask or remove the screen and paint the scuttle panel completly,blending in with the roof halfway up the screenposts,get some waxoyl on the underside of the repair and it should last ages.
eldarvanyar
Post Wed Aug 09, 2006 5:22 pm
Kos
Post Thu Aug 10, 2006 2:43 am
you can get the scuttle from bmw but its bull shit, as you have a vew vin number punched in and its in a different location which may put off any possible future buyer, because the car will look like a ringer
also police inspection may be required as well ( this is what i have been lead to belive!)
i have cut off the sections from recent breakers for my own cars
dmaxfield
Post Thu Aug 10, 2006 9:54 am
you can still buy a new scuttle and just cut out your bad bits and weld in new bits as it is a major job putting in a new scuttle properly .
eldarvanyar
Post Thu Aug 10, 2006 10:01 am
Is it worth using filler or welding a metal plate is part of a new scuttle the way to go?
m3ben05
Post Thu Aug 10, 2006 10:12 am
I can only speak for M3 scuttles but iv heard the new parts are shocking quality. The number is stamped on so badly it looks fake!
IMO its best to try and repair the original scuttle if at all possible.
appletree
Post Thu Aug 10, 2006 8:07 pm
Heres mine i got a mate whos a pipe fitter in dairys to tig the plates in for me :D
Before. i coverd it with a plastic cut out and silocone to stop the weather getting in till i could get it fixed properly.
All the bad metal cut out. i also painted the inner wings with zinc paint and then covered it with red gloss paint.
And here it is all welde up ready to be flatted back and painted. :D
Simon
Post Thu Aug 10, 2006 8:13 pm
As has been said, buy a new scuttle from BMW, and cut out the rust, and cut the ends from the new scuttle, a new scuttle is only about £40 anyway.
jcjdavis1
Post Thu Aug 10, 2006 9:40 pm
HI I have same prob on n/s.How easy is it to take wing off
or can you partially take wing off for the repair?
Need some tips on how to get wing off please.
Kos
Post Fri Aug 11, 2006 1:31 am
in some cases it gets the bottom of the screen, now thats bad!!
appletree
Post Fri Aug 11, 2006 12:56 pm
the wing iss only bolted on so its pritty easy to remove :D
jcjdavis1
Post Fri Aug 11, 2006 1:31 pm
Hi I think I will move over to the tech. section and ask about removing wing.
tez
Post Tue Aug 15, 2006 12:08 am
Is it safe to weld in new sections with dashboard in place or is it best to remove , i can see mine going up in smoke knowing my luck? :?:
Simon
Post Tue Aug 15, 2006 4:43 pm
tez wrote:Is it safe to weld in new sections with dashboard in place or is it best to remove , i can see mine going up in smoke knowing my luck? :?:
Depends where the rust is, if it's around the glass frame, then it will be near the dash, and will require dash removal.
