I was amazed at how easily it all went together,e36 engine,box and prop dropped straight in with no mods,i used e28 engine mounts and a standard e30 gearbox crossmember,a porsche 944 servo for engine clearance,this needs the thread lengthening and a bit chopping off where it attaches to the pedal,a standard e36 325 rad so i could dispense with the separate expansion tank for a neater look,no viscous fan,just a 12"electric blower in front of the rad,xs-power headers,a supersprint middle section and a standard M3 rear box,you need to make a balancer exhaust section between the downpipes and the centre box so you can fit the oxygen sensor.The wiring is not as bad as you might think,quite alot of the colours correspond,alot of the wires on the engine loom side are not used,you need the c101 plug off an e30 engine loom and cut the plug off the m50 engine,then get soldering.No problems on the fuel side just a feed and return,the fuel filter is mounted on the side of the block,the power steering pump and reservoir do not need to be moved but i did need to have new hoses made.whipsey wrote:how much work ws involved in the conversion and what sort of cost only asking cause im still not sure what to do with mine
