hi,
i would be greatful if you could tell the easiest way locate and remove the engine temp sensor on my 316i m40, its got the same cold start up problem as everybody else seems to be experiencing.
any pics would be great
cheers
mike
engine temp sensor on m40
Demlotcrew
Its the blue one under the inlet manifold.
Andrew
Andrew
smithy318i
if anyone says it's easy to replace they are telling lies.
it's below the inlet manifold in the middle of the head. best to remove the manifold for better access, but unless you have fingers like ET, it aint easy.
Chris-W
