engine temp sensor on m40
mike_w
Post Thu Aug 03, 2006 5:34 pm
hi,
i would be greatful if you could tell the easiest way locate and remove the engine temp sensor on my 316i m40, its got the same cold start up problem as everybody else seems to be experiencing.
any pics would be great
cheers
mike
Demlotcrew
Post Thu Aug 03, 2006 5:57 pm
Its the blue one under the inlet manifold.
Andrew
smithy318i
Post Thu Aug 03, 2006 6:13 pm
if anyone says it's easy to replace they are telling lies.
it's below the inlet manifold in the middle of the head. best to remove the manifold for better access, but unless you have fingers like ET, it aint easy.
mike_w
Post Thu Aug 03, 2006 7:46 pm
cheers guys :D
Chris-W
Post Thu Aug 03, 2006 8:03 pm
As Smithy says, take the inlet manifold off, and use the opportunity to fit new intake gaskets.
mike_w
Post Fri Aug 04, 2006 5:40 pm
thanks
