chipping a standard 325
JCB
Post Mon Jul 31, 2006 11:20 am
are there any BHP gains to be had by chipping a standard 325. the only mod it will have is aribox removed and replaced with cold air fed cone filter. is it better to change the cam if i am chipping or are there benefits on a standard engine ??
Post Mon Jul 31, 2006 11:22 am
better off with the standard airbox and a chip imo..
chip sees an 8bhp or so gain i believe
JCB
Post Mon Jul 31, 2006 11:57 am
so what you are saying is that the boys from munich probably got the design right in the first place !!!
dazleeds
old skool raver
old skool raver
Post Mon Jul 31, 2006 12:00 pm
a chip from ant will give you nice gains and iron out any flat spots etc
also possible fuel economy gains
but removing the airbox for a cone is a real no no on most e30s
all it usualy does is kill some power rather than gain any
Daz
www.oldskoolfantasy.co.uk
JCB
Post Mon Jul 31, 2006 12:30 pm
really ? !! the car came with a cone fitted and i just ducted some cold air in. i have heard the ITG foam filter is good ? . i spent ages making a box to go round the cone filter with heat reflective sheet on it to help keep the air cool. anyone got and airbox for sale ?? fuel economy is not an issue -only used on tracks. i want more power !!!
Cotty
Hartge Crew
Post Tue Aug 01, 2006 8:02 pm
dazleeds wrote:a chip from ant will give you nice gains and iron out any flat spots etc
:wink: I have one, very good I really feed the difference in the midrange. Im organising a rolling road day at Surrey Rolling Road in September so I can do a before and after run
Palazzo
Post Wed Aug 02, 2006 5:28 am
i'd be really keen to see the results with and without the new chip.
M5pilot
Post Thu Aug 03, 2006 7:06 pm
The ITG foam filters make a positive difference as a chip does.
Every single person who has fitted them and tested them back to back has said there is a noticeable difference which shouldn't occur in theory over the OE stuff.
Sal
HartgeH27
Post Thu Aug 03, 2006 7:11 pm
Debatable subject but I find genuine set up is the best........no disrespect to others but BMW got it right from the start.
