chipping a standard 325
are there any BHP gains to be had by chipping a standard 325. the only mod it will have is aribox removed and replaced with cold air fed cone filter. is it better to change the cam if i am chipping or are there benefits on a standard engine ??
so what you are saying is that the boys from munich probably got the design right in the first place !!!
a chip from ant will give you nice gains and iron out any flat spots etc
also possible fuel economy gains
but removing the airbox for a cone is a real no no on most e30s
all it usualy does is kill some power rather than gain any
Daz
Daz
www.oldskoolfantasy.co.uk
really ? !! the car came with a cone fitted and i just ducted some cold air in. i have heard the ITG foam filter is good ? . i spent ages making a box to go round the cone filter with heat reflective sheet on it to help keep the air cool. anyone got and airbox for sale ?? fuel economy is not an issue -only used on tracks. i want more power !!!
dazleeds wrote:a chip from ant will give you nice gains and iron out any flat spots etc
i'd be really keen to see the results with and without the new chip.Cotty180 wrote:dazleeds wrote:a chip from ant will give you nice gains and iron out any flat spots etcI have one, very good I really feed the difference in the midrange. Im organising a rolling road day at Surrey Rolling Road in September so I can do a before and after run
The ITG foam filters make a positive difference as a chip does.
Every single person who has fitted them and tested them back to back has said there is a noticeable difference which shouldn't occur in theory over the OE stuff.
Sal
Sal
