how do you know if your bushes are gone?
i have just bought a jemax -40mm drop suspension set up and plan to fit it this weekend.
thing is, i have been assuming that my strange lift off over steer is mainly down to warn shocks, springs etc and could it be the bushes?
how can i tell? feels like the car twists slightly but dont know if that is my bouncy, dead shocks?
bit of advice would be nice so i have a good idea of what to look for wheni take teh suspension apart.
also how long does it take for the springs to bed in?
cheers.
suspension bushes
Morat
When the bushes are shot your car develops a case of what my girlfried calls "swingy hips".
Apart from that I guess you're looking for play in the joints.
Chris-W
Jack it up on the rear axle and see if it's bushes drop noticeably, eg. if the axle raises right up to the bodyshell, they are definitely shot!
MadE30mike
So u would recomend a polly bush kit if i was lowering my car?
ric325i
i will test this before i take the susspension apart on sat morn.
i think i do have a case of "swingy hips"
whats it like changing bushes? should i do this at the same time as i do suspension and whats better...... do i put standard bmw parts on (cause we know bmw parts are good) or do i up-rate?
Chris-W
Personally I'd put standard bushes in.
Bit of a lousy job requiring, besides normal tools, a press, a gas torch, a lump hammer, a friend and patience.
