M40 owners
smithy318i
Wed Jul 26, 2006 11:09 am
Does your car shake when the engine is at idle?
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Wed Jul 26, 2006 11:19 am
Yes! it never used to but the idle is getting lower (should it be about 1500 till it warms up?) mine tries to idle at 850-900 from cold sometimes, i suspect the cold start sensor/switch!
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
smithy318i
Wed Jul 26, 2006 11:24 am
mines at 900 whatever the engine temp. it idles like a bag of shit at the mo. :cry:
dazleeds
old skool raver
old skool raver
Wed Jul 26, 2006 11:32 am
idle at 1500 8O
thats a bit high aint it??
www.oldskoolfantasy.co.uk
dobbie82
Wed Jul 26, 2006 11:46 am
dazleeds wrote:idle at 1500 8O
sorry I don't know what it should be at warm up, was a blind stab in the dark! I am used to rovers and thats what they do! :oops:
Wed Jul 26, 2006 12:15 pm
nope - rock solid steady
jcjdavis1
Wed Jul 26, 2006 2:54 pm
lump free
slinky
Wed Jul 26, 2006 3:15 pm
Yep mine does as well, got very little history with it so don't know when timing belt was changed last so going to replace that as a precaution and see if I get a smoother idle as a result as well. If not cold start sensor switch is next!
Gibbo
Wed Jul 26, 2006 5:19 pm
Loads of M40s seem to struggle at idle and mine's never really improved over 15 years of mentioning it to the service engineer. But this is different to a lumpy shacky experience on cold start. This seems to be common as the miles get high and I guess only some sort of rebuild will solve it.
bmwe30mtech
Wed Jul 26, 2006 5:34 pm
Mine is silent at idle now, not because it still stalls!!, but because its so smooth. They should idle arround 900rpm. 1500 is way too high.
Bob_S
Wed Jul 26, 2006 5:37 pm
my 316i was crap on cold startup would do alsorts of wierd shit, so I bought an is which incidentally is perfect! lol
Bollocks to this 24v scrap!
essexboy
Wed Jul 26, 2006 5:41 pm
mine used to idle really lumpy wen the thermostat stopped working and was running hot resulted in a cracked head on the 316, 318 i have now idles well touch wood at about 900 rpm, there can be a phew causes for a lumpy idle
bmwe30mtech
Wed Jul 26, 2006 5:45 pm
The M40 idle is riddled with problems, i have seen/been in so many with problems. Mine dint idle for about a year, it just cut out, so you would constantly have to hold your foot in the acellerater a bit! :x . I just sdjusted the bulkhead in the end. If yours is lumpy its probably idleing too slow, what does it idle at?
Edit, just seen it idles at 900 :? , dont know then. ICV, AFM, air leak..
burt
Wed Jul 26, 2006 5:53 pm
yep it shakes. When i start it from cold the revs are all over the place and it almost stalls unless you get your foot on the pedal.
NIX
Wed Jul 26, 2006 8:41 pm
My 318i used to shake a lot on a dodgy idle. Replaced the inlet manifold gasket and it seemed to sort things out. Now being converted to a 325i so we'll see how that goes.
jonbuoy
Wed Jul 26, 2006 9:10 pm
Check for hole's or split's in the air pipe going from the afm to the throttle body. This would most probably be your problem, usually split underneath :wink:
smithy318i
Thu Aug 10, 2006 3:42 pm
could it be a faulty engine speed sensor?
maxfield
Thu Aug 10, 2006 4:00 pm
My dads M3 shakes afair bit at idle. Iknow I aint an M40 but maybe something to do with 4pot. And thats on freshly built engine.
hammoj28
Thu Aug 10, 2006 4:16 pm
My IS shakes a bit and is lumpyish but it runs good so im not really bothered anymore.lol. Someone told me all the M3's were lumpy at idle and shake and that IS's do the same.
24v tech2
Bob_S
Thu Aug 10, 2006 5:34 pm
because we have real engine mate ;) lol
I've yet to come across an e30 with a dead level idle
