Fuse no 20
tomski
Post Fri Jul 07, 2006 5:03 pm
Hi Can anyone tell me what fuse no 20 does please. Its a 30 amp in at the moment but its a bit melted.
Thanks Andrew
ad318i
Post Fri Jul 07, 2006 5:04 pm
right fog light!
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
tomski
Post Fri Jul 07, 2006 5:10 pm
Thanks for that quick reply mate, do you have any idea as to why it might melt ?
Cheers Andrew
ad318i
Post Fri Jul 07, 2006 5:11 pm
nah im not sure about that but someone will be along soon enough to give ya more info
Post Fri Jul 07, 2006 6:02 pm
Quick reply maybe, but totally incorrect!
Fuse 20 is for the heater fan and aircon, if you have it.
Heater fan can seize, and stall current might just about be enough to blow the fuse.
tomski
Post Fri Jul 07, 2006 7:35 pm
Thanks for that, I have just fitted a new fuse and the heater fan does not work now but I know that it was last time I used the car. Can the heater motor be repaired or will I be better off looking for a second hand one and is it easy to get at it.
Cheers Andrew
ad318i
Post Fri Jul 07, 2006 7:41 pm
oh yea for some reason, i just checked again i read no 30 on the fuses!! :oops:
tomski
Post Mon Jul 10, 2006 7:05 pm
I took the fan motor out today It was a bit tight but I connected it to a battery charger and it worked fine. I then ran a test light onto the wires for the fan and nothing on any speed. Do the fan switches go faulty and if so could this have caused the fuse to melt
Cheers Andrew
Post Mon Jul 10, 2006 8:35 pm
The multi section resistor that is switched into circuit at positions 1, 2 and 3 can go faulty, but it's not in circuit for position 4, and shouldn't be responsible for fuse blowing in any case.
The motor should turn freely. Try running light oil into the bearings while its running on the battery charger
Check to see if you have power at the fuse - or check to see if the mirrors work. They both get power from relay K7.
tomski
Post Mon Jul 10, 2006 9:48 pm
Hi thanks again. I have checked and the mirrors still work. I will check in the morning to see if I have power at the fusebox.
Cheers Andrew
tomski
Post Tue Jul 11, 2006 1:55 pm
Hi The mirrors still work ok but I dont seem to have power to the fuse, I checked from both sides again with a test light and nothing. I pulled out the k7 relay and pin no 87 looked like it had been hot. Is it possible that the relay could be at fault or is the fact that the mirrors still work enough to say its ok
Thanks Andrew
Post Tue Jul 11, 2006 8:05 pm
Mirrors are on fuse 19, right next to 20, and joins to K7 pin 87 socket by a printed circuit board. Difficult to see how power can get to one and not to the other, except for a very severe dry joint.
Easy enough to open up the fusebox to check. Four screws (one hidden under a relay), and ease the top up. Nothing will break or come loose, except for a 5 or 6 pin plug that might partly pull off. (Obviouds when you see it).
tomski
Post Tue Jul 11, 2006 8:19 pm
Hi, Thanks for all your help with this, I will pull it all apart and have a look.
Cheers Andrew
tomski
Post Fri Jul 14, 2006 6:06 pm
Right all fixed now. Took the fuse box apart and had a good look at the fuse holder itself and it was a bit dirty bits of plastic etc. Cleaned it all up fitted a new fuse and it seems ok now
Thanks Again for your help
Andrew
ric325i
Post Sun Jul 16, 2006 10:35 pm
hey guys i have had the same problem with mine and i posted a topic which i plan to return to tonight. been a busy boy this weekend (all work and lots of play).
this link has been a great help and i plan to fix the old smoker asap now i have this info.
also cheer brain for the advice i wish i was quicker on the reply.
tomski
Post Mon Jul 24, 2006 8:42 pm
Hi my heaters have stopped working again. In the fuse box under the board there is a 5 pin plug but I cant see anywhere for it to go back onto any ideas ???
Cheers Andrew
Post Mon Jul 24, 2006 10:04 pm
White 5 pin plug pushes onto the row of pins sticking out of the PCB.
tomski
Post Mon Jul 24, 2006 10:12 pm
Are these pins all in one line. The plug that I have in the fuse box is more like 3 pins on top of two if that makes sense ***
Cheers Andrew
Post Mon Jul 24, 2006 10:22 pm
Aah! I know the one you mean! Never seen it connected to anything, and I've no idea what it's for!
All the wires from it go down into the cabin, but I've never traced them, and they don't appear on any of my wiring diagrams as far as I can tell.
