Indicator fault
camcc
Post Mon Jul 24, 2006 9:28 am
My indicator is not turning off automatically when I straighten out from a turn....any known reason for this?
Theo
Post Mon Jul 24, 2006 9:29 am
Is your steering wheel on straight? If not, this is probably the reason.
alan325i
Post Mon Jul 24, 2006 9:50 am
Hard to explain this but u will see it when and if you take the indicator stalk off.
On the part of the indicator that fits to the steering column there is a springed lever. This locks either up or down depending on which way u r turning, when the steering wheel turns the opposite way it releases the lever and turns off ur indicators.
smithy318i
Post Mon Jul 24, 2006 9:51 am
the indicator stalk has a small plastic lever on the inside. this lever may have worn away or have broken off.
camcc
Post Mon Jul 24, 2006 11:56 am
Steering wheel is definately on straight :-)
I can see the little lever and it moves very slightly when I move the indicator up and down......looks like it may have worn to be honest.
May look to changeit as it is a little annoying - having you indicator left on for 10 mins after you've made a turn.
Steviec
Post Mon Jul 24, 2006 12:11 pm
Mine does the same, is it possible to just change the plastic part or do you have to replace the who indicator stalk (mine has the OBC control on it aswell).
smithy318i
Post Mon Jul 24, 2006 12:25 pm
Steviec wrote:Mine does the same, is it possible to just change the plastic part or do you have to replace the who indicator stalk (mine has the OBC control on it aswell).
you will need to drill out the rivets.
i would replace the plastic bit from a non obc stalk if you have an OBC stalk fitted. otherwise just replace the whole thing.
Steviec
Post Mon Jul 24, 2006 12:38 pm
Sounds like a bit of a bodge job to me, so I should be quite good at it lol!
Thanks for that, ill hunt down a decent non obc (cheap) indicator stalk.
<a><IMG></a>
MikeeMiracle
Post Mon Jul 24, 2006 12:58 pm
camcc wrote:My indicator is not turning off automatically when I straighten out from a turn....any known reason for this?
Heh....I had this driving down town. I got into Oxford street and then the car started drifting to the right. I tried to straighten the car but nothing was happening and the wheel was just turning. I came to a stop in the middle of Oxford street and then I pulled the steering wheel and the fooker came off 8O 8O 8O 8O
As the wheel had physically moved it was no longer touching the stalk to turn the indicator off, now at least I know what to check for next time. Make sure your steering wheel is screwed in tight :)
Red 318is
Take me to the land of the twisty's :)
