Injectors and dizzy - Megasquirt
jamesc
Post Fri Jul 21, 2006 8:42 am
Hello,
I'm (slowly) progressing with my MS install - intially going N/A with a view to turboing maybe over the winter. My first question is should I fit bigger injectors now or wait until I turbo? Can I get a set that will work well for both so I don't have to buy 2 sets?
Secondly, can I keep the dizzy or should I be looking at fitting a coil pack? Is there a suitable one around?
Cheers. James
Ant
Retired Team Member
Retired Team Member
Post Fri Jul 21, 2006 10:15 am
keep the dizzy as is for now James, works sweet with MS, makes the build easier too mate
you're OK with the stock inj or now too mate, the PWM % will indicate whether you have enough flow long term though.
HTH
jaistanley
Post Fri Jul 21, 2006 1:09 pm
I'm inclined to agree about the distributor. If it aint broke, dont fix it.
If you really want to go to a coil pack I personally think you should go for a ford 6 pot edis setup acompanied by a ford style crank position sensor.
Jai
Turbo-Brown
Boost Junkie
Post Fri Jul 21, 2006 1:38 pm
Thought MS could directly control a coilpack without the EDIS stuff?
Personally reckon that if you can at some point upgrade to a coil pack, especially with a turbocharger installed, it's a worthwhile mod.
With coilpack ignition you should get a much fatter spark than is possible with a single coil which means you can run a bigger plug gap which in turn should lead to a more complete and efficient burn, the need for less ignition advance and so help to reduce the likelhood of detonation. :)
It's win win really!
jaistanley
Post Fri Jul 21, 2006 5:50 pm
I'm not up on Megasquirt these days... I looked into it a while back to fit some bike throttle bodies to my 16v Golf but that was an age ago.
If it can control a coil pack without the EDIS, that's excellent!
I agree with all your points about the advantages too, I just suggested start with the distributor at first as to reduce the number of un-knowns when installing..
Incidentally, can MS run a bank of 6 direct fire packs (a la later beemers)?
Jai
WillG
Post Fri Jul 21, 2006 7:32 pm
im not sure how many drivers MS has, i know you have 6-8 on vems but you only need to use 3 on m20's, no need for CDI unit and dissy, i have 3 of these coils im fitting
http://store.summitracing.com/partdetai ... toview=sku
e30_Turbo
Boost Junkie
Post Fri Jul 21, 2006 8:37 pm
MS will control a single coil as std, but you can add up to 7 additional drivers if you really want to go for it
no need for the EDIS module although technically easier to implememet if you do but you loose some control options that way
Cam position sensor is nrq either way
HTH
