hi all
after reading a couple of other posts about 073 chips in earlier 325is', i've heard that they can be modified to suit a 28 pin chip and i have 2 questions.
1) would anybody be able to tell me how to modify the board myself (it would cost to much to send the whole computer to the UK as i live in australia) and
2) what chip number would be suited to this modified board
thanks
e30 #073 chip?
Ant
- Retired Team Member
the mods required are simple enough dude
open the ECU
seperate the upper PCB from the lower board
add 4 extra pins to the upper board, the holes are already there
remove existing 24 pin eprom, replace with new 28 pin unit and away yu go
the 073 ECU's use a diff motroinc version to the later, any chip must be specific to the 073
I've sent a few to AUS and NZ over the years, always well recieved.
HTH
open the ECU
HTH
Email FTW
Ziggy
It really is as easy as that, & Ant's chips rule!
mitchell_owens
cheers for that, the ecu is now 28 pin
for the wild chips in the e30 zone store, will they work with my now modified ecu? and also is the only way to pay for them using the gift card things? (i couldnt see any other payment type)
Ant
the Zone shop accepts all payment cards ( debit/credit) dude
international cheque is fine too.
Email FTW
