Urgent keys locked in Cab boot!
black320
Ok yes I feel very stupid but need help. I have locked my only set of keys into the boot of my covertible. Can get into car on drivers side etc but keys are locked in the boot.
Is there any way to get into the boot in a cab without using a scewdriver and hammer and breaking the boot lock???
If not what is the best way of breaking in????
Cheers.
Cheers.
fowler
- Boost Junkie
lock the door from inside then unlock again should work ???
EX A-Tech Workshop bitch !!!
gone but not forgotten
black320
sorry should have mentioned, no central locking on the car.
Dealer can get you a new key from the VIN, locksmith or local equivalent of the AA, or destroy one of the rear light clusters and reach in.
black320
Would it be easier / cheaper to destroy the light cluster than break the boot lock?
Chris-W
You're less likely to suffer collateral damge if you go in through the light cluster, as long as you're careful!
cliffybabe
- Powered by Nelly
I'd go through the lights not fun though
Chris-W
Yep - wear gloves!
There was footage on TV a while ago of a couple of police officiers breaking into an E30 boot. Car didn't look pretty afterwards.black320 wrote:Would it be easier / cheaper to destroy the light cluster than break the boot lock?
black320
So its not going to be easy then but the rear lights sound like a good option, its a pity the car is in a busy car park!
stuartgallafant
cliffybabe
- Powered by Nelly
stuartgallafant wrote:yeah, get a cordless angle grinder and just go at the light cluster mate!
jon_pure_british
if it has no central locking may i ask how they got locked in there?
Clacton-On-Sea
Essex
Essex
stuartgallafant
cliffybabe
- Powered by Nelly
ive heard of this b4 i didnt know it was on a e30 thoughstuartgallafant wrote: you can have the lock in whats known as 'chauffer position' where you must have the key to unlock it!
stuartgallafant
black320
no angle gringer but I have a hammer... anyone any idea of how much locksmiths cost? Would one be able to help without breaking lock?
cliffybabe
- Powered by Nelly
i know someone who paid about 150 once, but ur in italiy so i dont have a clueblack320 wrote:no angle gringer but I have a hammer... anyone any idea of how much locksmiths cost? Would one be able to help without breaking lock?
black320
also is there any possibility of going through from behind rear seats or is it just a wall of sheet steel?
stuartgallafant
black320
I had a look but all I saw was steel... maybe if there was a hole just to get hand through to get keys...
stuartgallafant
JohnH
Ring a mobile locksmith - it'll be the easiest in the long run and they'll be in the car in a couple of minutesblack320 wrote:Ok yes I feel very stupid but need help. I have locked my only set of keys into the boot of my covertible. Can get into car on drivers side etc but keys are locked in the boot.
Cheers.
cliffybabe
- Powered by Nelly
na no ski hatch on a cab due tot he structure support etc, there some gaps in the steel however they aint that big
tjd200
if there are holes any chance you can get a telescopic magnet pen thing through there?
cliffybabe
- Powered by Nelly
dont think u could mate there barley big enough to get speaker cable through
stuartgallafant
cliffybabe
- Powered by Nelly
it depends how bigger bunch the keys arestuartgallafant wrote:or a coathanger?
stuartgallafant
cliffybabe
- Powered by Nelly
dont pick on mestuartgallafant wrote:you didnt say that at 1st did you, you twat!!cliffybabe wrote:dont think u could mate there barley big enough to get speaker cable through
i did say it u, mentioned the ski hatch
that does it
dazleeds
- old skool raver
put a chisel in the lock and hit it with a bloody big hammer
in theory this should kill the barrell and pop the spring off the back and you should be able to open
heard this recently but havent tried it myself
last time i had this prob i had to cut the boot lid in half to get in
even that was a bloody nightmare as e30 bootlids are a lot thicker and stronger than ya think
www.oldskoolfantasy.co.uk
stuartgallafant
when i mentioned the ski hatch, i said "im not sure"cliffybabe wrote:dont pick on mestuartgallafant wrote:you didnt say that at 1st did you, you twat!!cliffybabe wrote:dont think u could mate there barley big enough to get speaker cable through![]()
i did say it u, mentioned the ski hatch![]()
that does it![]()
black320
Is there enough room to get an old wire coat hanger through??
cliffybabe
- Powered by Nelly
there is but it depends on how many keys u have and were abouts the keys are ur gonna have no light in there at allblack320 wrote:Is there enough room to get an old wire coat hanger through??
paulj
been there done it
locksmith is the way forward mate will ben in there in a matter of minutes and most of the time with no damage, its worth the extra pennies mate to have it done properly
Hope tis helps
Hope tis helps
