can anyone talk me through it? i would really like to get this sorted today!!
cheers
Which will be dried out very quickly when the bat cable rubs through.Templ8e30 wrote:or you'll get a soggy carpet !.
Iain T
whereabouts under the dash board??Templ8e30 wrote:The cable will appear from under the dashboard, you'll need to remove the cover under the dash to locate it.
To route the cable to the boot you need to remove the rhs front speaker cover and slide out the plastic trim running along the bottom of the door opening, then remove the rear seat base.
The cable follows the wiring loom along the side of the car and pops out into the boot from the rhs corner of the rear seat.
Make sure you secure the cable properly along its route, you don't want this un-fused cable rubbing through the insulation.
Also make sure the rubber grommet is seated correctly where the cable runs from the engine bay into the passenger compartment or you'll get a soggy carpet !.
Cheers,
Iain T
