So I took I ordered a new A pillar mutiplug and pins as they needed changing and a new central locking module
So go outside and take out kick panel and take out plug and what do I find wires fcuking everywhere not plugged in and I can not find where they should be plugged in so this is where I need your help
1. Black plug on the left not plugged in anywhere just stuffed behind speaker with the black and red wire coming out of it connected to the white plug which goes on the central locking module so where and what does this black plug do ??????
Next
2. 3pin plug in middle of pic is not plugged in anywhere either it has a brown/blue wire coming out of it and goes into the a pillar mutiplug and a green/purple wire coming out and going to the central locking module any ideas ???????
3. Then I have a grey/green wire coming out the mutiplug with a connector on the end not plugged in any ideas????
4. Then I have other wire coming out the mutiplug a grey/yellow wire with a blue plug on the end guess what thats not plugged either
Last one then I have a green/blue wire with a white connector on the end and thats not plugged in and as you can see two red/yellow wire just hanging around doing nothing any ideas welcome
Help
