will touring springs fit a cab
tommy22
Post Sat Jul 15, 2006 11:13 am
Lee_Coupe
BEWARE Zone Thief
Post Sat Jul 15, 2006 11:31 am
They will fit,
But it be higher due to the weight difference, also the spring rate will be different.
12345kevin
Post Sat Jul 15, 2006 11:33 am
I think the cab is heavier at the back, so would sit lower :D
gareth
Post Sat Jul 15, 2006 12:47 pm
they'll fit and the ride height should be about right. the spring rate will be about right too. it's not 100% perfect but a lot better than saloon ones.
if the rear sits a bit low, it's a relatively easy job to get some shims made to raise it a tad.
