will touring springs fit a cab
tommy22
Lee_Coupe
- BEWARE Zone Thief
They will fit,
But it be higher due to the weight difference, also the spring rate will be different.
12345kevin
I think the cab is heavier at the back, so would sit lower
gareth
they'll fit and the ride height should be about right. the spring rate will be about right too. it's not 100% perfect but a lot better than saloon ones.
if the rear sits a bit low, it's a relatively easy job to get some shims made to raise it a tad.
