I plan to rolling road mine also,just out of curosity (sp?)bigpimpin wrote:I have a few "dents" in mine, I plan to get it rolling roaded when the dust settles to see what I have.
From what I've read, around 300bhp is about right for a good s50b32? I have the ecu etc from a ZM coupe but would hope to see the 300 mark.
Thanks mate.I will get my friend to take some pics for me as my camera is cack !Jhonno wrote:good work Buster
I know what ya mean there mate!buster wrote:nowt like taking your time eh![]()
It does look like it should of been there from the factory, it just suits it so well.Turbo-Brown wrote:Can't believe how factory that looks!
I had mine in place with the tailpipes as they are and it would fit, but its close to under the diff with very little ground clearance. I think your solution will be the easiest way round that.buster wrote: James,both tail pipes were chopped off and re welded on at the right angle
And all on the driveway(my bro's type R couldn't keep up).
Im not sure on the brace as i swapped my twin tube sparco one for it as it wouldn't fit with the 4cyl wiring cover in place.DanThe wrote:Looking great buster![]()
What strut brace is that your using? Have you got any details of where I can get one?
If you dont use those discs I will buy them from you if they dont allready have a home
