Im running Z3 brakes on the rear and 328 on the front.
The problem is when i go for a drive round the block and come back all my brakes are stuck on. When i release the vacuum from the servo it doesn't make any difference but if i unbolt the master from the servo and pull it away a little bit, the brakes release. And if i bolt the master straight back on afterwards the brakes are still released. So i thought it must be the spacer i made. Was to long and holding the brakes on. But when its bolted back on the wheels spin freely???
Now surely if it was my spacer holding the piston in on the master that was causing the brakes to stay on then when i pulled the master away it would release them and when i put it back on it would put them on again?
Has anyone got any ideas, pretty tired at the moment and probably not thinking straight
